Lq9 swap into cadillac sts?
Old 06-02-2011, 08:43 PM
99twinturbofirebird's Avatar
Default Lq9 swap into cadillac sts?
I was thinking of picking up a newer Cadillac sts and swaping an lq9 in it . has anyone done this and how hard would it be ?
Old 06-02-2011, 11:30 PM
itsslow98's Avatar
not that i have heard but im sure its gonna be a ton of custom work and custom parts like headers etc.
Old 06-03-2011, 09:26 AM
yea i figured that ........ i would think all the custom work would be headers , wiring , motor and trans mounts
Old 06-04-2011, 01:18 AM
avatar4886's Avatar
If your talking a 2005+ STS those are on the Sigma platform. Guess what other car is on the Sigma platform, 2003-2007 CTS-V. It has an LS2 or LS6 under the hood depending on the year. The 08 CTS-V are on Sigma2 with an LSA.
Should be able to use mounts and brackets from the 1st gen CTS-V for your LQ9 swap. Possibly even the wiring harness/ECU/ect as well.
Old 06-04-2011, 01:30 AM
MasterTomos's Avatar
ARent the STS's front wheel drive though?
Old 06-04-2011, 04:26 AM
1dirtyZ's Avatar
isn't there an STS that already comes with an LS3 pointing in the right direction from the factory ? if i recall correctly isn't the STS-v an AWD LS car?
Old 06-04-2011, 09:12 AM
1CAMWNDR's Avatar
All 2005+ STS cars are either rear wheel drive or all wheel drive.
No, the STS-V is only RWD. And it has a Supercharged 4.4L Northstar. The non-V STS was available with AWD and the N/A 4.6L Northstar.
I would personally love to see a regular STS with an LS motor and a 4L80 swapped in.
Old 06-05-2011, 02:11 AM
1dirtyZ's Avatar
pooop , and i thought i had a lead on where to get an AWD oil pan for an LS1 other than the trail blazer pan
Old 06-05-2011, 09:55 PM
itsslow98's Avatar
Bottom line is without a power adder an LS/4l80 STS is gonna be a turd. Hell just take a first gen cts-v, remove the 6 speed and add another 400lbs and youll havea car that might break 100mph in the 1/4.
Now an LQ4 with a turbo and 4l80 and your talking, otherwise an STS-V isnt very ahrd to make 470rwhp and more torque then an N/A LSX.
Old 06-07-2011, 01:40 AM
was thinking on do a tvs 1900 down the road on it
Old 06-07-2011, 02:39 PM
1CAMWNDR's Avatar
Really? As easy as it is to get 400+ out of a mild build you think it will be slow? I bet an LS/4L80 heads, cam, headers, and a tune would smack the **** out of a '94-'96 Impala SS. And no one thinks those are "turds".
Quick Reply: Lq9 swap into cadillac sts?
