ABS INOP/TCS OFF lights
Old 06-03-2011, 06:42 PM
Siciliano15's Avatar
Default ABS INOP/TCS OFF lights
hey guys i wanted to see if anyone knows what could be causing this problem.... all of a sudden one day my ABS INOP light came on and the TCS OFF light came on and i cant turn the tcs back on. i checked all of the fuses and they were all ok. unplugged the battery and plugged it back in and still the same problem....
'98 trans am automatic
Old 06-04-2011, 09:05 AM
anyone ever have this happen to them? i read online it could be tied to the third brake light bulb but i checked those and they work so wat else could it be?
Old 06-04-2011, 09:34 AM
ULTIMATEORANGESS's Avatar
Smile
do you have over sized tires on your car?
Old 06-04-2011, 01:33 PM
no. 315/35/17 rear and 265/40/17 front. diameters are within ¼" of each other
Old 06-04-2011, 02:09 PM
Asian LSX's Avatar
It could be a wheel speed sensor.
Old 06-04-2011, 02:22 PM
rjparth's Avatar
Sounds like sensor/electrical to me. I'd be looking for damaged wiring and/or bad sensors if they both came on at the same time. Fuses too but you already checked them.
Old 06-04-2011, 02:45 PM
is there anywhere to check for codes or is it not stored in the pcm? hate to start changing all of the sensors if its just one....
Old 06-04-2011, 03:59 PM
92SilverSHO's Avatar
When my battery was on its way out, i had those lights popup off and on. New battery, no more lights and that was over 2 years ago.
Old 06-04-2011, 06:29 PM
CUR4VNM's Avatar
this happens to me in my 01 gmc sierra but it doesnt happen all the time, dont mean to hijack but i am interested in this too. hope you get the problem solved
Old 06-04-2011, 07:07 PM
nah its all good. i changed the battery just a few months ago with an OEM one so i guess its probably something to do with the sensors
Old 06-05-2011, 11:50 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Is the brake light on also?
Old 06-05-2011, 11:54 AM
Hashish's Avatar
I have been having some ABS related issues that trip a TCS off light sometimes, as well as throw the ABS Inop light, but never at the same time. Anyway, my issue is a bad/going bad wheels speed sensor. If you know anyone with a more in depth scan tool or take it to the dealer they can pull your ABS codes and you can see the problem.
Old 06-05-2011, 01:57 PM
rabbit320's Avatar
def check the sensors, and about a foot down the wire from the sensor going to the body (if that makes sense) there is another extension connector around the lower a-arms in front, and around lca's in rear along the same wires. for me it was this connection not the speed sensor that was giving it a faulty signal. also check your PWR ACCRY fuse on the panel inside the drivers door, cant remember why but this helped also; or other fuses in same spot or under hood...
Old 06-05-2011, 08:08 PM
CUR4VNM's Avatar
interesting but definately good things to look into
Old 06-06-2011, 08:16 AM
thanks ill try those things out. yep all 3 lights are on steady. "brake", "tcs off", and "abs inop"
Old 06-06-2011, 09:15 AM
Deviant LS1's Avatar
Get the codes scanned with an ABS scan tool and report back.
Old 06-06-2011, 09:33 AM
i have the HPTuners do u think that will be able to scan or does that only read the pcm?
Old 06-06-2011, 10:08 AM
JRENIGAR's Avatar
I have this problem and had it scanned with a snap-on scanner. It is the abs module itself going out. The 3 lights are off every morning when I first start the car and I usually drive for 5 miles or so and all 3 lights come on at once. When this happens the tcs sys is not able to be re acvtivated till the car sits overnight and all the lights go back out. I have since aquired hp tuners myself but havent tried to read codes with it yet. Hope this helps.
Old 06-06-2011, 12:55 PM
oh dam. good info. is the abs module an expensive piece to replace?
Old 06-06-2011, 06:06 PM
mypoorLS1's Avatar
ABS module. I got mine from a junkyard with a guarantee. It was still like $500 or something.
Quick Reply: ABS INOP/TCS OFF lights
