help, clutch problem
Old 06-04-2011, 10:51 AM
Nick99SS's Avatar
Default help, clutch problem
today i was driving my car and it was fine then i stopped to get gas started it and pushed in the clutch and it wouldnt go into gear. it was like there was a wall stopping it. the clutch felt fine and it didnt grind or anything and after about 10 mins i just started it again tryed to put it in gear and it went. so i just drove back home. one weird thing was whenever i had my foot on the clutch and tryed to put it in gear the car would start rolling forward. alright so whats wrong?
Old 06-04-2011, 11:37 AM
MJs1FastSS's Avatar
could be dirty fluid, line clogged or master clyinder going out.....either way once the master somes out you ll be able to check all of that
Old 06-04-2011, 01:43 PM
Nick99SS's Avatar
so the clutch itself is probably fine?
Old 06-04-2011, 02:12 PM
Zmg00camaross's Avatar
I had a simalir issue when installing my new clutch hard to get in gear and would creep. Replace the master cylinder with a Tick master and fix the issues
Old 06-04-2011, 04:34 PM
Nick99SS's Avatar
well its not a new clutch i honestly dont know when it was changed it has a ls6 clutch in it but idk when it was installed. but i really dont have the money to buy a new clutch so i hope that all it is is the master cylinder. but it hasnt done it again i havent drove it but i started it up earlier. its my dd so i need it to work lol
Old 06-04-2011, 04:37 PM
Nick99SS's Avatar
is this sumthing i can do in my garage or am i gunna need to put it in the shop
Old 06-04-2011, 05:02 PM
If you have any mechanical skills you can put a master cylinder in.
Old 06-04-2011, 05:05 PM
Nick99SS's Avatar
alright cool just makin sure but are you sure thats all it needs?
Old 06-04-2011, 05:18 PM
Nick99SS's Avatar
o ya and is it good to drive. cuz its my dd and i kinda need it lol
Old 06-04-2011, 05:20 PM
Not sure, Just going from my experence. Myself installed my clutch 11inch monster and creep going into gear and practical wouldnt go into gear. I could pump the pedal about ten times and would go into gear. So I order a Tick master installed it and adjusted and smooth as butter now. I imagine the stock master leak internally and bypasses the seals inside. But thats just my experence.
Old 06-04-2011, 05:33 PM
Nick99SS's Avatar
thanks i appreciate it. but i should be good driving it?
Quick Reply: help, clutch problem
