How do you take out the rear piece of an LS1 intake?
I bought a ls6 from a guy on the board and the heater? vacuum tube was filled and I was wondering if i could swap out that round piece on the back of a stock ls1 intake for the one on the ls6 but I have no idea how it comes out.
It's the part that holds the sensor and has 2 vacuum line connections on it. It wiggles around a bit but there are no visible ways to get it out that i can tell??????
it's probably got clips or something inside of it so it just goes in and not out i guess? maybe if i knew someone that had REALLY skinny arms i could get them to stick there arm back there
Originally Posted by SilverGhost
oil pressure sending unit is in the block..tall sensor right behind the intake..only sensor on the back of the intake is the IAT..
MAP sensor, not IAT
