traction control tuned out?
can i et the tcs to be off when i start the car through the tune? i have herd of the gto and trans am guys putting boxes that do it but no one makes one for the v......i only ask cuz i just blew up my axle cuz i forgot to turn tcs off just dont wanna do it again
I wouldn't be surprised if GM intentionally made it to where it could not automatically be disabled, for liability reasons. Not saying that's the case, just saying...
It's a PITA to remember to turn it off all the time (esp since you have to hit it twice to get stability 1/2 off too), but it's babit 98% of the time, unless it's raining rally bad, although even then I turn it off, as it almost feels less safe with it on, as it will allow some spin and rear end movement, but it kicks on at a bad time.
These cars are soooo much nicer than the GTO's as far as handling the power and not getting squirrly and the TC system is better, imo, as well. Yes, I owned a new 2006 GTO with 6-speed and 18's (235's) for ~4 1/2 years, so knew that car too well in that respect. That one had the T/C on the console, which I always liked better than on the steering wheel, like ours.
^^LOL, know what you mean...What happens with me is I mistakenly hit that buttong sometimes instead of the scroll up/down for the g-meter, temps, etc...
Guess we should be glad we don't have to open the glovebox door everytime though if it wasn't there, lol...
If this was a car I didn't mind hacking up, I'd put a button somewhere else, amongst a few other things that are pita in this car, but I just get used to it and happy to deal with the quirks for all the car is overall.
when it comes on abrubtly when you forgot to turn it off the rear hops real bad i mean worse then i have even in the rain i was at the track and i knew i was going to break an axle one day but i am very careful in how i launch and spin the tires one time i forget to turn the TCS off it bucked so hard i thought i got rear ended and the axle broke....btw im taking donations i think need a kidney for some gforce axles
You can disable through HP ....
There are mode settings (0 - 8), Spark control, fuel cut off(i think is off from factory for these cars) throttle control and a few other things that need to be done (TQ management etc)...
However, if ABS is tied to controlling TC, then well, you must still use the T/C button with the long hold to remove that... as there is no BCM control with HP.
Ill look into this a bit more to confirm as I know you can COMPLETELY disable TC with GEN IV, not sure about GEN III ECMs.
