Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Gforce Engineering 9" kits
Old 06-06-2011, 10:28 PM
Gforce Engineering's Avatar
Default Gforce Engineering 9" kits
Hey guys, just wanted to let everyone know that we have ramped up production and now have our 9" kits on the shelf ready to ship.
Say good bye to the clunks and parts breakage with stock rear, driveshaft and axles.
Our 9" kit gives you a complete solution and comes with our 1000hp axles, aluminum/Chromoly driveshaft, fabricated housing and you can also get a Stange Pro Iron pumpkin.
Only work required to make it bolt in is some clearance work on the cradle to allow for the larger cv joints.
Here is the link to our web site
http://www.shop.gforce1320.com/produ...&categoryId=13
Our 9" kits are also available for the 2010+ Camaro, Pontiac G8 and GTO.
Thanks
Chris
Old 06-07-2011, 01:38 AM
PeteRock's Avatar
Wish I had 4K to spare
Old 06-07-2011, 02:31 AM
itsslow98's Avatar
you mean 5500, i saw 4k at first then realized you had to add the center section.
Old 06-07-2011, 06:49 AM
UnsafeAtAnySpd's Avatar
Is the CF driveshaft still on the horizon?
Old 06-07-2011, 08:40 AM
greddy91's Avatar
CF driveshaft was already an option when I ordered my kit.
Old 06-07-2011, 10:10 AM
Oh okay. I thought that I had read that it was still on hold.
Old 06-07-2011, 10:45 AM
06blackonblackctsv's Avatar
Looks great, did the price go down? I thought it used to be $5k. I need to stop being lazy and get my gforce axle installed
Old 06-07-2011, 07:31 PM
shadyLS6's Avatar
chris,
do you think there is enough clearance for 3in exhaust pipes?
Old 06-08-2011, 09:53 AM
vmapper's Avatar
lol, its like 6 posts UP... ADD the center section and your over 5500.
Old 06-09-2011, 09:48 PM
We usually do the 2 piece on the CTS-V since it is such a long shaft but we can also do a 1 piece carbon fiber.
It used to be priced at $5500. for everything. We had some people wanting to buy it but supply their own pumpkin so decided to change the price to a "Base" price and then you add your pumpkin if you want one.
Thanks
Chris
Old 06-09-2011, 10:56 PM
My bad, maybe I need to learn how to read before I start posting, LOL. Chris I was thinking about getting the other axle, I already have the driver side axle waiting to be installed, do I just need to order the one for the 04-05? Is the price going to drop again, I bought mine right before the price drop last time,
Old 06-10-2011, 08:59 AM
shadyLS6's Avatar
Originally Posted by shadyLS6
chris,
Old 06-10-2011, 09:53 AM
whisler151's Avatar
From other forum...
Originally Posted by GFORCE1320
Not sure about clearing your B&B, if it is currently real close to the diff then it will probably require some modifications.
We are in Wichita KS.
THanks
Chris
Old 06-14-2011, 02:25 AM
GREG O.'s Avatar
Question 9" rear
Chris, u showed pics b/4 where u had to move back part of the frame and reweld it ....In this post u said u only have to cut the cradle....so what all is involved...still on the fence...since i have an 06 i haven't had any rearend problems at all...but adding 300+ more horses i think i will be jumping off the fence soon
Old 06-14-2011, 08:44 AM
GFORCE1320's Avatar
Correct, we changed the housing design so you dont have to cut on the cradle for the hounsing to clear.
But you still have to open up the cradle where the cv joints pass through.
You have to cut about 1/2" out of the top and sides and weld some plate back in there. It's not that bad of a fab job.
I'll have a cradle core in a few days that I can modify for someone if needed.
These pics will give you an idea on what is needed.
Thanks
Chris
Old 06-14-2011, 08:54 AM
GFORCE1320's Avatar
Thank you for the orders guys!
Quick Reply: Gforce Engineering 9" kits
