Truck Intake vs Car Intake performance
I am in the process of building a 440 ERL based motor for my Pontiac. I am interested in using a truck intake for added low end response and overall torque production. I am curious to know if there have been any comparison test's performed to show the difference in power of the truck vs car intake. I do not wish the engine to make power past 62-6400. Are there any drawbacks to the truck intake. I believe I have enough hood clearance to run it. A FAST 102mm intake is too expensive, plus I would like to run a factory TBSS engine cover.
Found this thread: *l92/L76 Intake Manifold Flow Comparison* by *Richard@WCCH* who is one of the sponsors on this forum.
Check out Mast Motorsports websight. They have engine dyno charts with both intakes. If you study them close you'll see the truck intake has better bottom and topend. Also Comp cams commented in a vvt article that the truck intake is slightly better. This surprised me as I had seen the flowchart from the thread mentioned above and it clearly shows the car intake flowing better. I guess flow numbers aren't everything.
I understand making a budget, I'm an M.E. - it all comes down to the dollar when creating a design. But you will most likely have investing in parts that will not live to their potential especially with your engine size.
That being said, it seems you potentially wasted money in other areas now... Its all a system as you already know, but I hope you dont neglect. Just food for thought......
He didn't feel the gain, if there is any,from the intake was worth the money
I don't see why it is surprise that I am looking for information on these manifolds. Yes, I am building an ERL motor, but does not mean I just throw $900 at FAST for an intake. I am doing my research and asking questions of people that have more experience with the LS motor than I do. Since I am not at the stage yet to purchase an intake, I am gathering info beforehand. If a production LS3 intake would be better, then it would make more sense to buy one of them used, and save the money for other items. This is my first LS motor build, not the first motor I have built. Thanks.
you really think fast is way over rated? i mean as for the truck intake it gained 15 hp peak over the ls6 manifold and gained across the board as a whole...people spend 300 hundred dollars on cold air intakes all the time and 200 on udp's for what 5-10 hp gains?
udp's are worthless too , which is why the 1 on my 04 wont be going back on with the new motor , ill be glad to enjoy the wonders of a/c at idle again , lol
