Question Car is dead this AM
Old 06-11-2011, 08:00 AM
Mels SS's Avatar
Default Question Car is dead this AM
Is there a fuse from the alternator to the battery for charging protection?
Last weekend I was at a car show and left the key to the on position for a few hours when I discovered this I tried to start the SS and it barley did on the way home the onstar was out and the indicator said very fast and went away about check charging system now it wont start any Ideas?
Old 06-11-2011, 08:11 AM
neilownz's Avatar
Try charging the battery?
Old 06-11-2011, 08:20 AM
Mels SS's Avatar
I'm doing that now and it's building power I'm at 9 volts currently.
Old 06-11-2011, 10:07 AM
gxp-miller-gxp's Avatar
once you get the battery charged make sure the terminals are good and extremely tight
Old 06-11-2011, 12:06 PM
texasGXP08's Avatar
You may want to consider a deep cycle battery since you show your car a lot. I have a optima yellow top and it is a beast.
Old 06-11-2011, 02:50 PM
Mels SS's Avatar
I have the red top
Old 06-11-2011, 03:07 PM
texasGXP08's Avatar
The red top is high output. The yellow top is high output and deep cycle.
Old 06-12-2011, 08:59 AM
Mels SS's Avatar
I will get the yellow top on the next one or if this one don't hold the charge. I'm at 12.5 volts.
Old 06-12-2011, 09:40 AM
neilownz's Avatar
Or put a switch in to flip to a second battery.
