samaurai with a 3.4 swap tuning?
anyone know if one can tune a 3.4 from a 95 camaro. i am installing one into my samurai and want to turn off vats and egr stuff. anything out there
try one of these sites, last i recall the 3.4 camaro is a obd 1.5 that cant be programmed.
http://www.thirdgen.org/techboard/?
http://60degreev6.com/forum/forum.php
I think you might be able to put a newer 3400 crank in it and get a wiring harness out of a newer grand am and make it a obd 2. Im pretty sure the crank sensors are different between the 3.4 and the 3400
You could go older and use an OBD1 system on it, but you'd have to switch the intake, either a TBI one from something like an S10 or a port style intake from an earlier F-body or a Fiero with the 2.8, so you could slide a distributer in to the back of the motor. This swap was very common for the Fiero guys about 10 years ago
If I was doing it, for your application I'd use the 1227727 ecm with the weather proof connectors, so you could mount it under the hood
