Too close to run??
Too close to run??
Guys, I was just doing some ptv checking and I got about .080-.085 on both intake and exhaust on LS3 heads going on a LQ4. Is this too tight to run?? The intake seems 'ok'ish from what Ive read, but the exhaust might be a bit tight.
I might have to do that cheap-o fly cutting trick and sacrifice a couple couple valves.
So I just went and did the playdoh method. Check out the pics, I got. The tightest I measured was about .125, which is pretty good actually. Please look at my pics and see whats going on here. Its weird cuz I got such different values by mocking up and measuring with a dial indicator on the valve retainer and pushing on the rocker. I have checking springs installed.
What do you guys think of the way this looks??
well we were told by Advanced Induction on a friend of mines LT1 build that they go as tight as .050 on intake and exhaust... I thought that sounded tight but they know their stuff...
I think you would be ok with those clearances... However if you do Flycut..you would only need to on the exhaust side...
Matt, its an out of the box comp cams part number 54-470-11.
Intake Duration at 050 inch Lift 235
Exhaust Duration at 050 inch Lift 251
Duration at 050 inch Lift 235 int./251 exh.
0.621 int./0.624 exh.
LSA 113
I dont know what to think about this ptv clearance I got. One way I do it, I get really tight, another way I get lots of clearance. Just weird.
LSA 113
With a dial indicator you got .080"-.085" at TDC pushing the valves down by hand? With playdoh you got .125"... was that pushing the valves by hand or turning the motor letting the cam move the rockers and valves?
I might actually go and do this again and put the playdoh down and put the dial indicator on the spring retainer to make sure its going down the entire amount and not squishing the lifter. Im sure it didnt, but measuring is the only way to find out for sure.
EDIT: Also, that .080-.085 was actually not at TDC, it was a few degrees before I believe. I didnt have degree wheel on when I did that. But it wasnt at max lift Im pretty sure.
Yes, a head gasket was in there too.
I did some more playing, found out my lifters (especially the intake one) were squishing about .100 or so and therefore throwing off my readings.
So I converted an old lifter to be solid and re-did the playdoh method with a dial indicator on to make sure all the lift was coming in. It was. The playdoh still looked good actually, the smallest I got was on the exhaust around .120, which is good, I think.
So with "solid" lifters, a head gasket totally torqued down the thinnest playdoh I got was around .120. The thinnest is where the top of the piston dips down into the dish of the piston, along that edge there.
Thanks Ron, I appreciate the help. I did the check it every few degrees thing too. With the pics of the playdoh, you can see there is lots of clearance there. I think the playdoh doesnt lie, it will show the minimum clearance no matter where in the rotation it happens.
I actually sent you a PM back before I seen you came back in here, I appreciate the help.
The cam I WANT is a custom spec 231@.050" w/ .617" lift and 243@.050" w/ .624" lift 113+4 on LSL lobes
I know my heads cut .030" make it closer to the piston, but your increase in duration also puts you closer to the piston. I just wonder by how much though...
My pushrods are 7.425", that was given to me from the guy who sold me the cam. When I swap cams I want to measure it to verify.
What lifters are you running?
Also, your head gaskets crush to .051", correct? Would you be able to do a quick mock up with a .020" shims and the playdoh? If you cant its cool just wondering while your engine is on a stand.
I am running Comp 850 lifters. Im not sure, they could be the same as something else, like an LS7 lifter....I dont know. Those gaskets supposedly crush to .051". I took a previously crushed one and mic'd it while pressing it together, and the smallest number I could get was .051".
Ya, Im going to put the heads on today and close this chapter of the engine assembly I hope.
Thanks for the help guys.
Im going to obsolutely lose my mind.
Today I decided to check ptv with the dial indicator and solid lifters in and torque the head down with a gasket and checking springs in. Intake I got like .035 intake, .070 exhaust before the valve stopped going down. Im going to stab myself in the eye with my dial indicator soon. I even pushed on the valve and rotated the engine a bit to make sure it was hitting the piston and it was the piston.
How is this possible?? Im so pissed right now, I dont know what to do anymore.
