wtb a few parts for turbo build
I've got a set of Siemens Deka 60# injectors. EV1 style connectors. Ran for less then 1k miles. With a bunch of passes on them. Only upgraded because I've switched to E85 and now they're too small.
300$ shipped to your front door.
Please PM if you're interested.
They look like this:
ok update:
got the flanges (exhaust and t4)
might have a set of injectors (waiting to hear back from a friend)
things needed now-
Waste gate (60mm preferred)
Fuel setup (pumps, lines etc)
Water/meth kit (won't be running intercooler for now)
misc piping
bump it up.
things needed now-
misc piping
bump it up.
ok just to update:
following parts have been aquired
317 heads
ls6 valve springs
ls6 cam
5.3 motor gets here monday
gt4294 turbo (supposed to be a t88 but oh well) use this for the fall I guess
Spohn solid lsx mounts
ebay fmic
jgs 56 mm bov
jgs 50mm wastegate
twin walbro 255's
fuel pressure gauge
truck manifolds, flanges
merge collector is finished
1/2" billet fuel rails, aeromotive regulator
Alternator relocation kit
3" charge piping, couplers and t-bolts
ls6 intake manifold
still need:
basically a complete rebuild on the 5.3 (new bearings, head gasket, arp hardware)
injectors (80lb or 96lb)
boost controller (well don't need right away)
Wideband
oil pressure gauge
3 3" vband flanges and clamps
3 bar gm map sensor
brake proportioning valve
and I think that's it for now. will update once I go through the car this weekend
317 heads
ls6 valve springs
ls6 cam
ebay fmic
jgs 56 mm bov
jgs 50mm wastegate
twin walbro 255's
fuel pressure gauge
ls6 intake manifold
still need:
Wideband
oil pressure gauge
3 bar gm map sensor
yeah I know, starting off on only 10-12 psi due to stock drivetrain and my trans is pretty much shot. Doing a bunch of work on the car over the winter (th400, 12 bolt etc) and then I'll go with a better spring. Just trying to get the car up and running before it gets to crappy out to drive it this year
