What did I do wrong
What did I do wrong
I just installed my p&p throttle body and now the car idles at 1000rpm and it seems to stick when I rev it up.Also it starts to increase and decrease in idle. All input needed.
Thanks Mike
Thanks Mike
Well I took it off and put it back on and also did these steps...
Key off.
Unplug TPS.
Turn key on for 5 seconds.
Key off.
Plug in TPS.
Turn key on. Closed throttle should be 0%.
Key off.
Unplug TPS.
Key off.
Plug in TPS.
Who ported the TB? It could be that it wasn't done correctly and its not sealing completely. And as far as the TB sticking when you press the gas all of my P&P TB's had that feeling compared to stock just takes some getting used to
The guy has a great rep here on ls1tech and I only seen one complaint...I do understand that **** happens...tomorrow I will drive it around,I'm just not getting thd turn the a/c on part?
Is the amount of air coming in that big of a difference compared to stock?I'll drive it after work and post up the results around 6pm
Update...I drove it it seemed like it stopped until I got home now. I drove with a/c off for 10mins then on for 10mins and nothing. I drove the car for over an hour and now the rpms also stay at 1000rpms. So what now?
