Pontiac GTO 2004-2006 The Modern Goat
Some suggestions for a 2004...
Old 06-22-2011, 10:16 AM
J E T's Avatar
Question Some suggestions for a 2004...
I've tried using the awesome search function, but can't seem to find much for 2004 goats. I used to own a 2000 Z28, so I'm not new to LS1's. But I know mods are more expensive for these goats!
It's bone stock, except with stock mufflers taken off and straight pipes put in place by previous owner.
Some cheap and simple mods I am doing this weekend are:
*160 degree thermostat
*skip shift delete (that 1-4 shift is dumb)
*new plugs and wires
*SLP LM1 resonators welded in
Any other cheap and simple mods I can do before I start digging in with full bolt ons? Thanks!
Old 06-22-2011, 12:17 PM
NasbaGoat's Avatar
*Window weld the center of the trans mount to make it a solid mount
*Lou's Short Stick
*bleed clutch
Old 06-22-2011, 12:36 PM
Death{AW}'s Avatar
CAI, headers, cam :-D lot of suspension parts :-D
Old 06-22-2011, 01:03 PM
impulsegoat's Avatar
Descreen the maf, bump stop mod on tb, and pull out the tow brace, spare tire/jack, and the cage in the trunk. All free and should pick you up a few tenths.
Old 06-22-2011, 02:05 PM
Now you have my attention
GTOSE's Avatar
05/06 Brakes
Drag Bags
Long tubes
Old 06-22-2011, 02:09 PM
mark21742's Avatar
Poly bushings and springs
Old 06-23-2011, 08:36 AM
J E T's Avatar
Thanks guys! Keep them coming if you have any more!
Old 06-23-2011, 08:41 AM
mark21742's Avatar
You could pull the motor and drop in a 408 stroker... that's what I did
Old 06-23-2011, 08:56 AM
MD04Goat's Avatar
What's the cage in the trunk
Old 06-23-2011, 09:08 AM
svede1212's Avatar
*Lou's Short Stick
*bleed clutch
Those are great cheap mods. You can also use the balance of the Window Weld to fill the voids in the differential mounts for a "free" substitute to buying a poly one. Just make sure you give the Window Weld as much time as possible to cure before using it. 2-3 days is preferable.
Altho Lou's does give a shorter shift it doesn't address the lack of proper spring action to facilitate good 2>3 shifts. IMHO an aftermarket shifter should be the first real mod on a M6. Proxes shifter is a really good one at a reasonable cost with the GMM second.
The little bit of weight savings IMHO by gutting the back end isn't worth much. It removes safety features (bracing for the gas tank and the ability to change a flat tire) at the expense of losing weight at the wrong end of the car. You need weight back there for traction.
Old 06-23-2011, 09:51 AM
mark21742's Avatar
I know you mske the over the radiator intake for the 05-06, but do you make one for the 04?
If i still had a stock style intake i would have bought your setup in a heart beat
Old 06-23-2011, 10:57 AM
There's a picture somewhere floating around of a GTO that was rear ended at high speeds and the brace flew completely out of the car and is laying in the road, gas tank unharmed. It weighs about 25lbs. I know i have an auto and they hook easier but, i have zero spin issues with all of the above removed. The spare has been removed ever since i bought the car and has just been sitting collecting dust. AAA is worth the fat cut imo.
Old 06-23-2011, 06:37 PM
wlorton's Avatar
Go ahead and send the spare my way
Old 06-23-2011, 07:35 PM
v8
17,16,15,14,13,12,11 Drvr
v8's Avatar
magnacharger lol best bolt on modification lol ahahahaaa
Old 06-24-2011, 03:08 PM
J E T's Avatar
Where can I get a Proxes?
Old 06-25-2011, 01:57 PM
J E T's Avatar
Nevermind, I found their site. I think I'm going to go with the GMM one since it takes so long (2-4 weeks) for Proxes to build it.
Old 07-06-2011, 12:20 AM
Joeyelbows's Avatar
you can do the coolant bypass reroute. basically you take the hose thats goin to the throttle body and move it to the hose on the other side of the throttle body is. That way you dont have hot coolant running thru your throttle body. I'll see if I can find some pics for ya. Anywho the most you'll spend is mabey $5 if that. Just do it before you start your car.
Old 07-06-2011, 12:27 AM
Joeyelbows's Avatar
https://ls1tech.com/forums/pontiac-g...pass-do-2.html Near the bottom is some pics for you but you should already know of this mod.
Old 07-06-2011, 03:19 AM
Koondog's Avatar
drag bags! I think was one of the cheapest and most enjoyable mods.
Old 07-06-2011, 12:39 PM
Robofuzz's Avatar
Coilovers!!
Quick Reply: Some suggestions for a 2004...
