Clutch pedal stays on floor - 4th Gen
Old 06-28-2011, 03:57 PM
daytonajim's Avatar
Default Clutch pedal stays on floor - 4th Gen
Pedal wants to stay on the floor & have to pull it up with toe -
Sometimes clutch stays engaged a little when all the way in & can't shift
Intermittent - not every time...................
Has been OK except for 2-3 shifts are difficult (once in awhile)
I've done the 1/8" drill mod on 2 other 4th Gen cars & this one today.
(There are posts on LS-1 Tech on how to do it if you need to)
Other two cars are just fine - this one is not - nothing really changed.
Questions????
I wonder if I could have some air in the line even though I'm sure we bled it right?
Any other ideas????
What should I try next?
Thanks for any assistance.
Jim
Old 06-29-2011, 10:35 PM
99wssixm6's Avatar
Tick Master Cylinder .......... End of story!!!!
Old 06-29-2011, 11:02 PM
ssdeuce74's Avatar
it could be the pressure plate getting weak, my cars getting a low pedal after a beating. today when it happened i started playing with the pedal and felt a bump when the pedal came back up so definately a mechanical issue
Old 06-29-2011, 11:22 PM
AndyIsLost's Avatar
Try the Tick Master first, that helped out a lot but I was still having clutch problems, got an LS7 clutch and now that's all in the past.
Old 06-30-2011, 12:29 AM
LS1aiden's Avatar
Ya Im having the same problem you need to replace the clutch.
Old 06-30-2011, 06:12 AM
daytonajim's Avatar
Default Thanks
Thanks for the advise.
I guess I'll be putting in a new clutch.
GMMG Phase IIX/475hp
What's best? GM LS-7 clutch or something else?
Anyone have part numbers so I get it right?
Thanks again. Jim
Old 06-30-2011, 09:01 AM
ssdeuce74's Avatar
something other then the ls7 if your gona make any power later, i'm thinking about a diamond 2, or mcleod rst twin disc seem to be getting great reviews and the kits are far lighter then the ls7 from what i've heard.
Old 06-30-2011, 10:19 AM
Camaro9969's Avatar
Ticks are ok but you dont need it just get a stock GM master and a new clutch u will be fine. I got the Monster Stage 3 clutch its incredible grabs very hard wouldnt buy anything else. I take it to the track about 50 runs a year i got about 15 on this clutch and it pulls very hard and no clutch issues at all. Last year i tried everything like u and still stuck to the floor. I recommend the Monster Clutch over the LS7 any day. Plus its nice knowing you have something that can take some abuse and is very streetable.
Old 06-30-2011, 11:27 AM
BrntWS6's Avatar
You'd be better off with a level 1 Monster or Diamond as they are basically upgraded LS7 clutches. Only good thing about an LS7 is it's a bit cheaper.
Old 07-06-2011, 04:20 PM
LS1TECH Sponsor
Joey@Tick's Avatar
For a good read on hydraulics, check out our FAQ here: http://www.tick-performance.com/tick...aulics/#master
Old 07-06-2011, 05:31 PM
SNLPerformance's Avatar
I'd recommend Monster well over the LS7. Our level 1 is superior in everyway to the LS7 clutch, it's got a higher plate load and much better coefficient of friction with the material we use.
Give us a call and we'll get you into a Monster, if you do decide to get a Tick (and I highly recommend their product), Joey can hook you up with both the master and a Monster!
Old 08-01-2011, 02:38 PM
daytonajim's Avatar
Default Found the problem - thanks
Did 'drill mod' on 2 of my GMMG's & fixed the pedal problem.
GMMG PE #37 was different - took apart & found a cracked sleeve/spacer on the slave cylinder.
New LS7 clutch, flywheel, slave & other parts fixed problem.
Shifts & drives like new.
Thanks again for all the tips.
Jim
Quick Reply: Clutch pedal stays on floor - 4th Gen
