Suspension & Brakes - more c5 brake upgrade ???s
h_friesen
06-28-2011, 11:34 PM
Ill keep it simple. Is there a writeup somewhere with good pics that explains this step by step. I know ive seen it im on all the time but cant find it after 30 min of googling shit. Maybe some one can post a link :thumb:
ZexGX
06-29-2011, 12:58 PM
Steps:
1) Buy caliper bracket relocation kit.
2) Buy C5 front rotors.
3) Install kit and rotors per instructions.
4) Bed brakes.
5) Pick up some alcohol from liquor store.
6) Consume alcohol
7) Do not drive after step 6.
h_friesen
06-29-2011, 01:02 PM
That's the general idea. I didn't buy an actual kit just all the parts I need to do it. Im concerned with the brake fluid flush
ZexGX
06-29-2011, 01:13 PM
So you bought the spindle-to-caliper-bracket adapter plate & hardware? Did you buy the UMI components? The 6LE components? A "FRRAX special"?
Installation instructions depend on the parts that you have. Bleeding brakes is most effectively done with two people... One person pumping the brakes and holding, and the other cracking open the bleeder valve. Putting a small piece of tubing from the bleeder valve and into a bottle w/brake fluid in the bottom is a little trick you can use to prevent air from getting sucked back into the system... In addition to the instructions you can find in regards to bleeding the brakes.
h_friesen
06-29-2011, 03:57 PM
Haha I like step 6-7. Does the abs need to be bled or how to avoid getting any air into there? Guess put a banjo bolt with the washers on the caliper line right after I take off the old ones
ZexGX
06-29-2011, 04:25 PM
Good recent thread on bleeding the ABS system:
http://www.ls1tech.com/forums/suspension-brakes/1390297-bleeding-brakes-abs-tcs-car.html
How-to starts at post 33.
Before that, just bleed the brakes as normal with the two-man method.
h_friesen
06-29-2011, 07:13 PM
read the entire post and it has a lot of good info that i needed thanks. Is there another writeup about the actual install of the brackets and calipers and such? im sure id be able to do it but some steps and tip are nice to have.
Jimmy P
06-30-2011, 01:12 AM
I believe it was BMR or UMI that have a link on their website to the instructions with photos. They show you which part of the spindle to cut.
ZexGX
06-30-2011, 12:39 PM
Assuming he has brackets that requires cutting of the spindle. He never did say what brand they were...
h_friesen
06-30-2011, 08:11 PM
the brackets are kore3 sorry i forgot to post that
z28MP
07-04-2011, 04:47 AM
I think ls1howto.com has a write up for doing the c5 brakes on an fbody. It's been a minute since I was on that site though, so not 100% sure.
ramairJP
07-04-2011, 09:49 AM
I can't speak for the other brands, but I bought a set of "trackbrackets" that came with a set of instructions for the whole install.
ZexGX
07-04-2011, 11:58 AM
http://www.kore3.com/proddetail.php?prod=10105-01
Looks like you bought the brackets that require spindle modification. You could always try to contact Kore3 for the instructions.
Kit installation requires minor to moderate, irreversible spindle modifications with basic metal fabrication tools. All necessary modifications are detailed in the instructions.
Minimum ø17" wheels are required with C5/C6 ø325mm rotor kits for caliper to wheel clearance. All 1996 and later 17" F-body wheels fit, however not all aftermarket ø17" wheels fit. Minimum ø18" wheels are required with the 340mm and 355mm kits. Please verify fitment prior to ordering using the appropriate KORE3 fitment template. Wheel fitment is the buyer's responsibilty. Please contact us if you have any questions regarding your specific application or the proper use of the templates.
