Quick LT Header install question
Old 06-29-2011, 12:22 PM
607motorsports's Avatar
Default Quick LT Header install question
Hey guys, I just recently purchased a beautiful black 2002 SS SLP 345 car and got a new set of the coated Pacesetter long tubes and TSP ORY with the car that the previous owner threw in.
I have read the numerous install threads on here and have everything needed for the install (including motor mounts) so i'm all set there but i'm just curious how high I need to get the car to install the headers. Unfortunately I do not have access to a lift for a few weeks and I really don't want to wait that long. Would a set of ramps on the front tires be sufficient or do I need to be higher?
Thanks ahead for the advice
Old 06-29-2011, 12:45 PM
Jay-P's Avatar
Well unless your ramps are 2' up, your going to have to go higher.
Old 06-29-2011, 12:48 PM
KING Z28 HAWK's Avatar
You need to get the car up pretty high I think I had my jack maxed out and it still wasn't high enough so I put a black of 4x4 wood on top of the jack pad and it gave just enough room. I have big truck jack stands so they were great. I'll post some pics when I get home.
Old 06-29-2011, 01:05 PM
RoidedSS's Avatar
i had to place my floorjacks on a few sheets of plywood that i cut to act as platforms to get my car the extra.....6-10 inches it needed to get the passenger side in. Just have extra jack stands under your car in case anything slips.
Old 06-29-2011, 02:22 PM
Thanks for the advice guys. The car really needs to be 2' in the air though?
I honestly hate working under anything with just jacks and jackstands it just feels so sketchy to me. I've got a couple sets of jackstands and a few jacks so I guess i'll just put them everywhere once I get the car high enough.
Old 06-29-2011, 02:34 PM
wickys98ta's Avatar
just put lts on my car. jacked it up and placed it on jack stands no extra needed, but i guess everyones can be different
Old 06-29-2011, 03:10 PM
I guess I'll have to give the jackstands a try maxed out and use the other stands and jacks elsewhere for support. Hopefully it will be enough to squeeze the headers up in!
Old 06-29-2011, 03:44 PM
yep 2'
Old 06-30-2011, 10:49 AM
LS1WS6dreamer's Avatar
I read another thread where a guy said 1ft between the tire and the ground was minimum. Guess i'll find out for myself in a couple months.
Old 06-30-2011, 01:21 PM
Yeah if you look at my 3rd pic you can see that the bottom of the tires is right at 12"
Old 06-30-2011, 10:45 PM
ta420nk's Avatar
The hardest part of the install is getting the car high enough.. And stable enough.. To get em in.
Good luck.
Old 07-03-2011, 11:25 AM
Thanks to everyone for the advice with this. My buddy and I were able to get the headers and ORY in yesterday, we also did motor and tranny mount as well as some NGK tr5 plugs and MSD wires and of course a custom tune using HPTuners. It ended up taking us around 8 or so hours. The car sounds great and there's a very nice noticeable increase in power
Old 07-03-2011, 12:06 PM
99Bluz28's Avatar
That looks to be about how high I had mine when I installed my LT headers and how high KING Z28 HAWK has his.
Old 07-03-2011, 01:09 PM
King Nothing's Avatar
i took mine off yesterday and it was close to 2' in the air, 2 pieces of 4x4 between my 3 ton jack and the k member
Old 07-03-2011, 01:16 PM
Brennen's01SS's Avatar
Man just make sure Youre aleast 20'' off the ground.
Old 07-03-2011, 02:39 PM
^yep!!! also have two 6 ton jack stands to support it and you'll be golden
