Coolant Blowing Out Of The Overflow
I have had this problem for a little bit now and I cant think of the solution. It only happens at wot and it doesnt happen all of the time but when I get on it coolant flys out of the overflow all over that side of the engine bay. I have gone through 3 radiator caps and they seem to fix the problem for a little then they start losing pressure. Could it be coolant in a cylinder even though I am not blowing white smoke and my oil is clean? Or could it be something else?
I have seen bad head gaskets cause this. when you floor it the head might be lifting up and pushing exhaust into the coolant forcing it out of the overflow. Seen it a bunch of times on boosted hondas.
hhow about when you shut the car off? does coolant come out of the over flow cap?
iirc..i had this problem when the car was turned off and the 2 hoses that go th the fittings on the radiator right below the radiator cap were on backwards...the overflow line goes to the upper fitting, the lower fitting goes to the engine steam pipe.
I am gonna try to replace the t-stat and go from there
The system has pressure. Thats the first thing I did, but the caps keep blowing out after a while and losing pressure. Ill get a tester but there is no oil in it unless that tests for gas as well and what would the fans not kicking on have to do with it shooting out?
