oil pump part numbers?
Might double check your part#.. Im showing the oldest part# to be 12556434... That was the # back in 99'... They have since changed to 12586665, which is all that is used from GM on the 4.8, 5.3 exc LC9 & LS4, 6.0 exc L76, 5.7(LS1 & LS6) & 6.2's exc L99 & L92
http://www.neweraperformanceparts.co...mart&Itemid=54
Click on part number 10296.
A melling M295 is the OE Replacement as opposed to the high performance 10296. The 10296 is a high volume pump and comes with two springs to allow the selection of standard pressure or high pressure (+10 psi). An M296 is a Melling pump for Chrysler engines.
I do not know - perhaps it helps if you are running an external oil cooler; or perhaps there instances where the higher pressure is beneficial with certain bearing clearances. I installed my with standard pressure spring. I wanted the added volume which comes with the 10296.
just talked to new era and they said that is the check off for the 10296 and there computers must have glitched cause it is not showing the checked boxes on the invoices he said it's actually 25 dollars more than the 10295 and to send it back and he will cover shipping I just gotta pay the diff
