th400 problems
1 Post
4.11 in 3rd gear should be near 3900ish
You're still in 2nd gear...
http://www.kabamus.com/garage/gears.html
based on a 1st gear - 2.48, 2nd gear - 1.48, 3rd gear 1.00
1 Post
yes, 84.5 at 6000 rpm in 2nd gear!
125.1 at 6000 rpm in 3rd gear
RPM - 8000 7500 7000 6500 6000 5500 5000 4500 4000 3500 3000 2500 2000 1500 1000
3rd Gear 166.8 156.4 146 135.5 125.1 114.7 104.3 93.83 83.41 72.98 62.56 52.13 41.7 31.28 20.85
2nd Gear 112.7 105.7 98.62 91.58 84.53 77.49 70.45 63.40 56.36 49.31 42.27 32.22 28.18 21.13 14.09
What is the fluid condition? It could easily be that you're blowing through the converter. Was the converter built specifically for your combination?
Is the tranny equipped with a brake? What is the max stall speed of your converter?
