95 motor in 97 car; just switch crankcase covers?
Old 07-02-2011, 06:26 PM
97385formula's Avatar
Question 95 motor in 97 car; just switch crankcase covers?
ya im putting a 95 385 ci into my 97 firebird it came with a tuned pcm but its a 95 and wouldnt work so now im in the process of swithing cranckcase covers for the cranck sensor. is there any thing else you could think of that i need to switch. or is there a way to make the 95 pcm work. with a 97 harness
Old 07-02-2011, 07:29 PM
Wicked94Z's Avatar
i'll buy the timing cover if you're selling
Old 07-02-2011, 07:55 PM
3DFORMULA's Avatar
you will need to add the crank piece that triggers the sensor
Old 07-03-2011, 09:27 AM
thanks 3d thats what i was really wondering
Old 07-03-2011, 09:40 AM
gotta sell the cover with the motor that is now a 97 setup for a 95 with 105k onit longblock for 400 as soon as i know this new motor is good hopefully tonight ;-} be interestin with my stock tuned pcm
Old 07-04-2011, 04:17 PM
1961ba427's Avatar
It would be far simpler to just throw the 95 engine and PCM in as is. It should already have the correct knock sensor in the block to match your pcm. The computer will plug right up to your 97 harness. You will now be OBD1.
Old 07-04-2011, 06:46 PM
will my instruments on the dash work since they are different in a 95
Old 07-04-2011, 06:50 PM
will it run if i just switch timing covers and leave the reluctor out and use the same hub or will the pcm shut it down
Old 07-04-2011, 08:23 PM
1961ba427's Avatar
Your guages and everything else will be uneffected. Your whole car will now "think" it's a 1995 model essentially.
You don't need to swap timing covers if you stick with the already tuned 95 PCM.
Old 07-07-2011, 12:22 PM
i would but pretty sure the 95 ecm is bad tries to start then its like it shuts it down and my guages are all messed oil pressure guage goes all the way up right when u turn the key. so my question is will it fire without the relucter or will the ecm safety need to be turned off. also the digital display is lit up with nothing on it
Old 07-07-2011, 12:50 PM
the 95 ecm was off an automatic and my car is a manual will this create an issue even tho im using my old harness 97
Old 07-08-2011, 03:17 PM
spike30th's Avatar
I have a 383 out of a 95 Camaro in my 97 Camaro. I kept my 97 Pcm.I ditched the reluctor wheel and stuck with the 95 timing cover and hub that came on the motor and had that sensor tuned out. My opinion is keep your 97 PCM and use the 95 timing cover and hub and just have the sensor tuned out.
