which 1 should i do first and which will show biggest gains?
Old 07-03-2011, 06:36 PM
my1rstls1's Avatar
Default which 1 should i do first and which will show biggest gains?
i have a choice to add either 373 gears into my car or a set off pacesetter longtubes and off road y pipe currently running 273 gears car runs a 13.81 @ 104 with a 2.15 60 ft.which should i do first?
Old 07-03-2011, 07:20 PM
CoastieWS6's Avatar
You should do a stall, then LT headers
Old 07-03-2011, 07:46 PM
my1rstls1's Avatar
the vehicle is my daily driver and has 135 xxx miles i am scared with this hot summer i will hurt the trans mission
Old 07-03-2011, 07:50 PM
608kZ28's Avatar
thats why they make transmission coolers.
but really, stall then headers, then a tune.
Old 07-03-2011, 07:51 PM
josh2002-ws6's Avatar
Well, swapping the rear end gears will put you at a higher risk of breaking that stock 10 bolt. The headers will help some. If you use the car as a daily driver and can't afford breaking it, maybe you should just leave it alone. Trust me, the more mods you do and track time you put on your car, the more likely it will break. Either the transmission or rear. Those are not cheap to fix either. What part of Maryland are you from?
Old 07-03-2011, 07:52 PM
tomstark's Avatar
The stock autos are fairly strong. I'd probably go with lt's if it's a DD.
Old 07-03-2011, 08:03 PM
my1rstls1's Avatar
im in temple hills md and as for the breaking i want to just get my car into the 12s with out a high risk of breaking i know its possible i have decent mph thru the 1/4 just need a better 60 ft
Old 07-03-2011, 08:04 PM
my1rstls1's Avatar
the car is hardly raced i just want a 12 second ls1 car for my self
Old 07-03-2011, 08:09 PM
my1rstls1's Avatar
also i have a set of stock 3.23 gears i am thinking of installing instead of 373 figured since they are stock gears cant be but so hard on my car
Old 07-03-2011, 08:19 PM
I had the stock 10 bolt with 3.42's and went 12.12. It is possible. I would have to agree with the other guy on a stall and tranny cooler. The 3.23's or 3.73's will work either way, both are better then the 2.73's you have now. It might be good for you to read this: https://ls1tech.com/forums/new-ls1-o...anna-fast.html
Old 07-03-2011, 08:39 PM
my1rstls1's Avatar
interesting information i really want a stall but for reliablity purpsoes think ima hold off for now even with a trans cooler stalls make transmission go out a whole lot faster.as for the gears i will probly instal the 323 since i already got them. and i will do the headers first since that wont put me at high risk of breaking also adding a cutout for when i need a beeter flow
Old 07-03-2011, 08:44 PM
tomstark's Avatar
Like stated previously, a good tune will add some extra ponies, especially with lt's.
Old 07-03-2011, 09:00 PM
^^^Very good point. If you are looking for a good tuner I can recommend some for you. PM me for more info if you want.
Old 07-03-2011, 10:14 PM
farmington's Avatar
I went 12.8 @108 with just 3.73 gears, 2800 converter, lid, SSRA air intake and a hand held tune. This was with a 2.3 60' (BFG street tires)
Old 07-03-2011, 10:28 PM
608kZ28's Avatar
i went 11.99 with a 3800 stall on a stock tranny with cooler. i have LTs, intake, few suspension goodies.
the 3800 stall is very driveable. more than i thought it would be
Old 07-03-2011, 10:32 PM
2fresh's Avatar
what is said above with decent set of tires
Old 07-04-2011, 08:44 AM
my1rstls1's Avatar
i have a buddy trying to sell me a tci streetfighter stall i believe its a 3200 to 3500 convertor for 200 bucks but here the whether is constantly over 90 degrees and with me driving every day even with a cooler ima afraid i will have some slippage
Old 07-04-2011, 12:38 PM
dannyz's Avatar
That is a NO on the tci stall. Many guys on here will tell you that.
They are a low quality piece and even if given to you at a killer deal, it would not be worth it.
About the 4l60e.
A lot of people will tell you its a pos, and that it will fail you in no time.
I myself have run over 28 bottles of nitrous through that trans, consistant 11.66-11.70's with 1.65 60' times for 2 years w/o any issue whatsoever, stock 10 bolt with 3.42 gears.
Now I did, [ just 6 weekes ago ] install a FLT lvl4 w/a yank ss3600 stall, to support my bigger nitrous shot [150].
But that trans was running as good as ever the day I pulled her out.
Regular maint. and a good cooler are very important for trans life.
And I am not an exception.
Do a search, and look how many guys are on their stock trans and running
11's, not to mention a few in the 10's.
The big question is how much money do you have to spend?
That will help us tell you what you should lean towards.
Old 07-04-2011, 01:01 PM
TheSilverOne's Avatar
-get some decent tires
-work on launching the car better
-a 3600 stall is very streetable. don't forget a trans cooler
the way the car is now you could get a 13.3ish out of it
Old 07-04-2011, 01:14 PM
808z28camaro's Avatar
When i read this i almost fell down laughing. Stock 4l60e are soft. ALL, i reapeat ALL 9 of my friends with a4s ALL had to rebuild their stock trannys with less then 100k miles. of course they do drive semi hard driving on the road and do visit the track once in a while. a few of them have heads, cam, 100 shot nos, bolt ons. most of them only have bolt ons. and yes they do the normal trans flushes etc.
His car has 134,xxx miles. It WILL need a rebuild soon especially with mods and track time.
to dannyz post. 28 bottles of 75 shot nos is not much. lol. jk you and those guys mentioned are lucky and probably dont have much milage, and use as a true daily driver. or just bsing about being stock trans.
