Ordered a Torquer V2!
Old 07-04-2011, 09:54 AM
EviL-S1-Z28's Avatar
Default Ordered a Torquer V2!
Just finished ordering a torquer v2 cam from Texas Speed. Since I'm on a budget, I just got the cam by itself. I know I will be needing pushrods and springs, so here comes my first question; Which springs would I want to go with? Beehive or Double? Can I reuse the factory spring seat/retainers? Moving on to the pushrods, do I order the 7.4s?
This will be going in a 01 6spd SS w/full exhaust, lid, stock engine, tranny, and rear.
Thanks. -Luis
Old 07-04-2011, 11:32 AM
epglxspooky's Avatar
When I ordered mine, I stuck with the single beehives. Guys at Tsp said I shouldn't see any problems doing so. I'll take their word for it.
Old 07-04-2011, 11:42 AM
poltergeist 02's Avatar
go with pac 1518 beehives. you can reuse your stock locks, retainers and seals with these. they are also one of the best beehive springs out there. you should measure for pushrod length, but if i had to guess 7.4" - 7.425".
Old 07-04-2011, 11:54 AM
suvettetexas's Avatar
The new comp 918's beehives should work fine, good for .625 lift.. only $169 from TS.,Stock retainers, seats and keepers will work. might want to put some new umbrella seals on her, theyre cheap enuff and good security, 7.4 pushrods should be fine with stock heads.. I am just about to put the same cam in my A4 firehawk, Good luck!!
Old 07-04-2011, 02:28 PM
wickedbluess's Avatar
7.4s with stock heads should be fine. Great cam ran it on my last set up
Old 07-04-2011, 03:11 PM
garygnu's Avatar
a TSP cam pkg is less expensive then buying a cam,springs ,and push rods separately..maybe you can still get the other pieces at a pkg price.
Old 07-04-2011, 03:47 PM
Restricted User
z99ls1's Avatar
Yea you should have gotten the package deal
Old 07-04-2011, 04:01 PM
01ssreda4's Avatar
Get the V3
Old 07-04-2011, 05:49 PM
Fbodyjunkie06's Avatar
V2 can run beehives, v3. requires dual springs
^^^Do you really think there is discernable difference between the two? I really don't see how .050" lift can change much...besides what springs it needs...
Old 07-04-2011, 05:57 PM
99Bluz28's Avatar
With stock heads, no!
Old 07-04-2011, 06:14 PM
anheuserbusch08's Avatar
use comp 918s or if u want go with the pac 1518 springs and with stock heads u should go with comp 7.4s. my friends trans am made almost 440 rwhp with a torquer v2, hand ported 243's milled .015 ls6 intake 3:73s and a 3400 stall cant go wrong with a torquer v2
Old 07-04-2011, 09:20 PM
Appreciate the comments guys, I was aware the package deal is actually less expensive, but had to take care of some bills, and only had x amount to play with, plus I didnt want to wait another 2 weeks Still have some time to make up my mind and order the springs/pushrods. Thanks again!
Old 07-04-2011, 10:49 PM
01ssreda4's Avatar
V3 is a better cam, ask TSP, they'll tell you.
Old 07-05-2011, 03:40 AM
PREDATOR-Z's Avatar
I do not agree with that.
Old 07-05-2011, 03:45 AM
01ssreda4's Avatar
That its a better cam or that TSP will agree? Opinion is subjective but I have seen them say the V3 is better.....more then once.
Old 07-05-2011, 04:14 AM
PREDATOR-Z's Avatar
Are you comparing 2 cams apple to apple?
Better yet, let us give it another twist! How about "does increase in overlap alone, increase horsepower/Trq?"
What makes it BETTER?
Have you been drinking marketing Koolaid
Old 07-05-2011, 06:26 AM
The torquer 3 is better when it comes to gains, but as for a dd, I would say not. The torquer2 has impressive gains and is a great dd cam.
Old 07-05-2011, 08:09 AM
01ssreda4's Avatar
I don't get into cams technical specifics, honestly its not my thing....and never will be. I have read a lot of reviews from owners, and from non-affliated sponsors, and ridden in a bunch of cammed LS1s.....that's where I form my opinion. Hearing TSP say they think the V3 is better is just icing on the cake. After all, it is the V3, which we all know 3>2.
Old 07-05-2011, 08:14 AM
1sicss's Avatar
Do yourself a favor replaxe your stock seals if your going to use stock heads. I got this cam which us really nice by the way but left stock valve seals and now im burning oil with the new hp oil pump. This may be a hit or miss thing but just change the seals while your in there.
Old 07-05-2011, 09:02 AM
BrntWS6's Avatar
TSP told me the same thing on the phone when ordering my H/C package. The V3 is on the LSX lobes and it will make more power everywhere over the V2. I have the V3 and if it were my DD I would have gotten the V2, but it's great for a weekend car.
Quick Reply: Ordered a Torquer V2!
