What first? Front shocks or T/A or ?
Old 07-05-2011, 10:30 AM
EZZZE's Avatar
Default What first? Front shocks or T/A or ?
This question has probably been posed a thousand times in different forms or fashions, but..... I can't make my mind up about what to do first on my suspension. I will give my current set up to help y'all make a decision.
'99 T/A lq4,L92 heads, cam, L76 intake, full bolt-on's
3.42 geared stock 10-bolt
stage 2 performabuilt 4l60e with Yank ss3600
made 402 rwhp unlocked on EPS dyno on motor
Nitrous Outlet 90mm wet plate kit
Anyway, my suspension is mostly stock except for an aftermarket k-member, non-adjustable lower control arms, and weld-in frame connectors. What should I do first? Adjustable torque arm? CE rear adj. shocks? Strange SA front shocks?
Old 07-05-2011, 10:37 AM
EZZZE's Avatar
To help clarify, the car hooks pretty hard on M/T 275 50 15 drag radials on welds. However, the 60 foot is awful....usually 1.70 - 1.75 with a best of 1.63 on motor. I hear of everybody going 1.5's or consistent low 1.6's. I'm not even close. I have been footbraking the converter. Should I flash it? Help me pick the next suspension mod....best bang for the buck. Thanks.
Old 07-05-2011, 10:49 AM
+badss+'s Avatar
id do strange da in rear and strange sa in front. that's what i'm going with on mine. ive talked to a couple sponsors about it. and you can get away with sa in the front, because your using a auto trans. hope that helps some.
Old 07-05-2011, 11:24 AM
EZZZE's Avatar
Thanks for the reply, badss. Keep em coming.
Old 07-05-2011, 10:04 PM
EZZZE's Avatar
Anybody else?
Quick Reply: What first? Front shocks or T/A or ?
