What first? Front shocks or T/A or ?
This question has probably been posed a thousand times in different forms or fashions, but..... I can't make my mind up about what to do first on my suspension. I will give my current set up to help y'all make a decision.
'99 T/A lq4,L92 heads, cam, L76 intake, full bolt-on's
3.42 geared stock 10-bolt
stage 2 performabuilt 4l60e with Yank ss3600
made 402 rwhp unlocked on EPS dyno on motor
Nitrous Outlet 90mm wet plate kit
Anyway, my suspension is mostly stock except for an aftermarket k-member, non-adjustable lower control arms, and weld-in frame connectors. What should I do first? Adjustable torque arm? CE rear adj. shocks? Strange SA front shocks?
To help clarify, the car hooks pretty hard on M/T 275 50 15 drag radials on welds. However, the 60 foot is awful....usually 1.70 - 1.75 with a best of 1.63 on motor. I hear of everybody going 1.5's or consistent low 1.6's. I'm not even close. I have been footbraking the converter. Should I flash it? Help me pick the next suspension mod....best bang for the buck. Thanks.
id do strange da in rear and strange sa in front. that's what i'm going with on mine. ive talked to a couple sponsors about it. and you can get away with sa in the front, because your using a auto trans. hope that helps some.
