lt1 build help
lt1 build help
Hey guys, this is my first build... im going 383 stroker... ported heads....cc306....stock intake... will stock rocker arms and lifters work with this setup? and can a programmer tune my stock 95 ecu? will the car even run without a tune haha? help please
2. and can a programmer tune my stock 95 ecu? Yes
3. will the car even run without a tune haha? Not with that cam..if it did it would run like ***
Since it's your first build, I suggest you make NO certainties since it is obvious you have a TON of learning to do. Find some combos that do what you want to achieve then go from there.
What kinda budget do you have, and what are your performance goals (HP or ET)?
there is a lot to learn. I just finished my first 383 build. I was a ton of fun. The cc306 is a nice cam but there are better ones out there. what are your hp/ET goals for the car? is it auto or stick? You will want to build your valve train for sure. I might have some things left over from my build that I will sell you really cheap. Let me look around and I will pm you.
