WTT/WTS 30th Anniversary 97 Z28 LS1 EFI H/C/I/Nos 383 stroker 608RWHP/595RWTQ
WTT/WTS 30th Anniversary 97 Z28 LS1 EFI H/C/I/N20 383 Moser 9 608RWHP/595RWTQ
Year: 1997
Make: Chevrolet
Model: Camaro
Price: $17500
Mileage: 84000
Private or Dealer Listing: Private Listing
Location (State): NC
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Looking to trade let me know what you have.
I'm wanting to trade my 97 Z/28 30th Anniversary Camaro"Rare Hardtop" I have had it for over 6 years now and just wanting something different. Im really wanting to trade for a 03/04 Cobra or a Lightning, or trailblazer ss, or a turbo or supercharged car. but I am open to other cars as well, Like something Supercharged or Turbocharged have Clean title and clean carfax report. I am open to other trades as well, so just let me know what you have. I bought the car with 56,xxx miles on it, It was BONE STOCK. I have put all the money into building this car. I have over 40,000 Dollars on reciepts for parts and labor for this car so dont lowball me and try to offer me 9,000 bucks like you are going to steal this car cause you are not; The engine and tranny work was done at 62,xxx, Rearend and chasis and suspension work was done at 73,xxx. New paint and Seats done at 80,xxx. Have all the reciepts for the parts on this car.
All work was professionally installed by Tick Performance In Moorseville, NC now they are in Mt Airy, NC been dealing with them for years they wont have a problem vouching for this car.
Update** Brand New 220 CncTea/ Trick FlowsLT4
and LT4 intake( Not brand new obviously but new on this car)
Makes 449 rwhp & 407 rwtq on Pump Gas 93 608 rwhp & 595rwtq on nitrous(Pump Gas 93).Text or call for ay info 336 432 6614
Joe Stewart in Moorseville, NC did the machine work
383 Stroker Kit Forged
Forged Eagle Crank and Eagle H Beam Connecting Rods
Forged SRP Flat Top Pistons with Nitrous rings
11:1 CR
Engine Work was done by Tick Performance in Moorseville, NC.
Total Engine Airflow/ Trick Flow 220 CNC LT4 Heads-2.055" and 1.600" Ferrea valves,67cc,Tea Springsgood for 650 Lift
LT4 Intake hand ported to match LT4 Heads
Pro Comp 1:6 Rocker arm set
"R" Series Lifters
GM Extreme Duty timing chain
7.200" Hardened Chromemoly pushrods
Bosch 42lb Injectors
Comp Cam 242/248 .584/.579 Cam 113 Hydraulic Roller
LS1 24X EFI Connection
LS1 Coil Packs
LS1 ECU and Wiring Harness
TPIS 58MM throttle body
ATI Super Damper
ARP Head bolt kit
MSD Digital Window Switch
MSD6AL BOX
CSR Billet Aluminum Electric Water Pump
ILE A/C Delete Pulley
Racetronix Fuel Pump Kit
Transmission
T-56
Tick Performance Stage 2 Rebuild Kit
Pro 5.0 Shifter
Spec Stage 3 Clutch
Spec Billet Steel Flywheel
Exhaust
Kooks Long Tube Headers 1 3/4 to 1 7/8 with 3" Collector
Kooks Custom 3.5 Y-Pipe
Borla Stainless Steel Catback
DMH Electric cutout on catback
2 DMH Electric Cutouts on Kooks Y-Pipe
Rear End
Moser 9" Rear End Assembly
4:11 Gears
Detroit True Trac wth 31 Spl Axles
LCA Relocation Brackets
Spohn Sway Bar Installion Kit
4 Channel ABS
Suspension/Chasis
Spohn Lower control arms tubular adjustable
Spohn Panhard Bar tubular adjustable
Spohn tubular adjustable torque arm-Long tube headers/ypipe-front& rear saftey loops
Spohn weld-in sub frame connectors
Eibach Pro lowering springs(front & rear)
Koni Sport "Yellow" Front & Rear shocks Adjustable
Spohn Front Sway bar
Spohn Shock tower brace
Other stuff
Brand X LT EFI Single Nozzle
Brand X Automatic Bottle Heater
LT1 Microswith and Bracket
Nitrous Outlet .125 Nitrous Solenoid
Nitrous Outlet .187 Fuel Solenoid
Brand X Purge Kit
Nitrous Outlet 93-02 F-Body Ashtray 4 Switch Panel
NOS Remote Bottle Opener
860 Bottle Mount Bracket
Auto Meter Ultra Lite Digital Nitrous Pressure Gauge
Auto Meter Ultra Lite Digital Fuel Pressure Gauge
Auto Meter Ultra Lite Digital Street Wideband
SLP Line Lock
Raptor Performance Mini Shift Light
Redtop battery
Tuff Stuff 200 Amp Alternator
Z06 Rims with 18x9.5 all way around, 275/35/18 front, 295/35/18 Bf-Goodrich Drag Radials* 20 miles on them*
Suncoast Fiberglass SS Ram Air Hood
Had seats reupholstered to match the car white and orange 30th Anniversary Logo came stock with just the white leather they were old and wore out and had them redone
All Videos were before head swap
This is a video someone took from the other week ran a 18lb r/t turbo neon, It was all motor for me no gas
Minor things wrong with it
*The rear hatch has a oil spot on the carpet where I had a quart of oil back there and it leaked out.
* Dash is cracked where I installed the gauges and was a lil rough trying to get them in and cracked the corner of the dash
thanks man It actually wasnt that hard to be honest, myself and a buddy did it ourselves, he did all the rewiring and stuff and we both put it in took us about 2 days total to do the swap, 1 day on wiring harness and 1 day on the install
i have a nice 01 yukon 4x4 slt loaded out sittin on procomp a/t 33s if interested,i had a low milage 30th anv. car but some one vandalized it and inshurance totaled it.i want another one.
I have one just like this but its a T-Top Z28.. with 3000 Anniversary Z28's built its kinda rare. Im keeping mine.
Your mods are sick! Im keeping the LT1 thats in mine for now but its .40 over mild cam.
Best of luck for a SICK LT1
