lt1 oil pump drive shaft
The plastic piece on my oil pump drive has snapped i have a 355 lt1 with the advanced induction head cam intake package...is there a drive i could find that's all metal? Or atleast a metal replacement for the plastic piece? Links are appreciated
I have a brand new never used Shon Herron billet aluminum housing with a Comp composite gear for $250 shipped, PM me if you're interested.
http://i1110.photobucket.com/albums/...T1parts014.jpg
http://i1110.photobucket.com/albums/...T1parts013.jpg
Village Troll
The title says it's a nylon sleeve, but the description states it is steel. You can always call Summit to confirm.
I think there is some confusion between the billet drive unit and an all steel driveshaft.
The driveshaft is a common gen 1 motor part, the $15 price on summit there is twice what I paid them a few years ago when I bought Melling was $7 and ARP was $12 seeing as the OEM plastic sleeve isn't that bad I figured the Melling more than sufficient.
The drive itself is dealer or the several posts above expired link to a billet unit.
even tq to spec the 19+ year old plastic is more brittle than new and can often crack. just making the small bolt "snug" with some loc-tite on threads works
IIRC there was someone making a cnc "cap" that just went over the plastic part. Have not seen one for some time.
I see in the link in post above someone is making Shons full cnc version again for $125
Realistically a scrap of metal or even a larger washer trimmed on one side can go a long ways towards insurance and used as a secondary hold down.
Really though almost all the risk is during install, haven't seen a report of one cracking in use and causing a problem, basically always during install.
from what I have "heard" (read not seen) the HV pump was attributed for wiping the gear on the drive, not cracking the plastic top. My $02 is in some if not all of those cases was a HV pump was used with stock bearing clearance motors or with billet geared cams. Or on re-install they were over tightened, plastic cracked then broke causing the drive gear to lift and wipe the gears on it against the cam gears as the two gears separated
HV pumps have a purpose and like any part are not for "every" motor or build.
I agree with Caprice that the majority cause of the plastic top cracking is over TQ (not necessarily over spec TQ but over TQ for a aging piece of plastic) on install after a cam swap using a 19-23 year old part that has a plastic top. I suspect the designers of the LT1 did not expect oil pump shaft plastic collars or the drive gears themselves to be a item removed and re-installed a few times especially after 100k mi
As Caprice noted a small washer that would fit in the recess flush with top then a larger washer over it and more of the plastic top would help "distribute" the clamp force from the very small area the stock bolt touches. maybe use a 1/4" longer bolt also if doing the stacked washer deal.
FWIW I have a HV pump and have had it in a motor for 9 years now. My motor was built with wider bearing clearances. I pulled it recently to look for any signs of wear when I did a rear manifold leak fix. It looked brand new. It is the original one and is 19 years old now
