9.00-9.99 upgrades (I think I have it all)
LS1Tech Co-Founder
Here is my list of things I need to install or had installed in the last 12 months:
External battery shutoff- done
Longer rear wheel studs- done
8 pt roll bar- done
aftermarket rear axles- done
CSI super shield/T400- done
SFI flexplate, TCI- done
SFI balancer, Vortech/ATI Super Damper- done
Longer front wheel studs, new Moser- not done
10 pt conversion, by Alston- not done
Kirkey drag seats- not done
Safequip 5 pt harness- not done
Window net- not done
Have I forgotten anything?
8 pt roll bar- done
I picked up a nomex lined helmet as well. Not sure its required.
About the only thing the Tech at no prob pointed out to me was making sure your cutoff switch is labeled. And your roll cage is padded where your helmet would likely contact it.
Larry
Larry
LS1Tech Co-Founder
Yeah I have no idea on the clothes, do the pants and jacket have to be a certain thickness?
I will label the shutoff thanks on that Larry. Which padding do you have, the big stuff or the one side U-shaped stuff?
"The Drag Racing Director"
You will need a 3 layer jacket, pants, Neck collar and gloves. I have the one side u-shaped stuff. It works great.
Coach
The Bull
It is 150 and higher. If you have good brakes you can bring a car down from high 140's on a short top end. Only risk to you is the new location for your beach front property if your brakes give out. That's a lot of speed to burn off. It's an easy thing to add at a later date and certainly not required for your speeds to pass tech.
Super Moderator
I have seen cars at the track brake down from 170 without a chute. I'd think if you are still on the factory discs they will be enough John. Unless you are on a track with a short shut down Weight is obviously a factor in this as well. A lot easier to stop a 2400 pound car I suppose Do you already have front studs? I have extras I got from Lingenfelter.
LS1Tech Co-Founder
I have some Moser mm studs I got from Summit a few months ago.
I am not so into the chute since I would have to do more chassis stuff to mount the 'chute stuff so I will most likely get some aftermarket front brakes now.
The Bull
Unfortunately with a chute you have to commit to your decision to use it before you reach about 1000'. Beyond that you'll be beach front in no time on a short track. Loose or not. And a chute may really upset a loose car if you are not careful. Choose wisely pison'. Aftermarket brakes are a really good idea though. I can stop so much better since I swapped mine out. Just feels a lot more consistent and firm.
Moderator
The question is how hard the tech guy will be. Everything is just about done on mine to run 9.00-9.99....Just ordered my pants and shoes...
This is a really interesting topic!!!!
Originally Posted by y2khawk
Multi-layer pants and jacket, 3.2A-5 is the spec i think.
Neck collar
gloves, shoes are suppose to be required.
Neck collar
8 pt roll bar- done
8 pt roll bar- done
LoL
