nitrous A/F ratio needed?
I am going to be getting a 125 shot wet plate kit within the next two weeks. Will I need an air fuel ratio gauge? How helpful will it be? Is it a worthwhile investment? Thanks for the help guys
If you are doing tuning you need a wide band. When spraying nitrous a wide band can give you an average of what your a/f ratio is but its always best to pull your plugs and read them to find your leanest cylinder. Your plugs will tell you if your lean or rich and I would always go off what the plugs say over just reading a wide band.
Guest
Posts: n/a
Agreed. While I do not want people tuning purely with a wideband, they are a great tool.
What about autometer gauges from summit. And what gauges do you recommended for a Nitrous set up? Nitrous gauge, a/f ratio wideband, fuel pressure etc? Thanks fellas
