no spark new cam and crank sensors
Old 07-18-2011, 05:17 PM
rickyruiz's Avatar
Default no spark new cam and crank sensors
i have a 1967 camaro ls1 tt one min i have spark then no spark changed the cam and crank sensors and still nothing i tryed to plug in the obd2 to check whats going on and cant connect to the pcm also have no 12v coming out of the pcm to the crank sencor do i have a bad pcm?help
Old 07-18-2011, 05:31 PM
rickyruiz's Avatar
can any one help
Old 07-18-2011, 06:26 PM
crainholio's Avatar
Last time I saw this the guy had connected his 12VDC ignition-switched feeds to the coil/injector connectors to a source that had no power during cranking (ACC circuit maybe?)
Old 07-18-2011, 06:29 PM
babbage1109's Avatar
Did you check your starter and ignition relays?
Old 07-18-2011, 10:22 PM
rickyruiz's Avatar
starter turns freely and i have no ignition relays
the wierd thing is that i cant make a connection to my pcm with the obd2 what do you guys think?
Old 07-18-2011, 10:23 PM
checked all fueses maybe a broken connector
Old 07-18-2011, 10:28 PM
rickyruiz's Avatar
i put a whole new wiring harness in it and still no spark
Old 07-18-2011, 10:40 PM
rickyruiz's Avatar
also changed my coil packs cam sensor and crank sensor im leaning towards reluctor gear on the crank or a bad pcm. i dont have 12v going to my crank sensor WHY??????
Old 07-19-2011, 12:32 AM
Big Black SS's Avatar
Check the fuse that powers your cigerate lighter, if its burnt or missing your obd won't work
Old 07-19-2011, 05:07 AM
crainholio's Avatar
Time to whip out your meter and wiring diagram and go to town. Could be a bent/damaged connector pin, a manufacturing defect in the new harness, or a blown PCM.
Start with the basics...probe for 12VDC to the PCM at both the constant 12V pin and the ignition-switched 12V pin.
Old 07-19-2011, 02:41 PM
rickyruiz's Avatar
i have 12v to the pcm and to the ignition but i cant seam to get any volts out from pin #2 #12#21 going to the crank sensor when key is on any guesses
Old 07-23-2011, 03:54 PM
rickyruiz's Avatar
i think my pcm is bad what do you guys think?
is there a way to check the pcm to see if its bad
Quick Reply: no spark new cam and crank sensors
