Manual Fan Switch
Manual Fan Switch
I have a 96 Formula A4 that I bought a year ago for 600 bucks. The fans were not coming on so I decided to test them out and they both turned on good and squeak very little at first. I then decided to try out the manual fan switch with led lights on shbox's website http://shbox.com/1/fan_sw_diagram2.jpg and to my surprise it worked but only for the high setting. My problem is that when I go to turn on the low I do see the led light turn on but the fan itself does not come on. The good thing is that the high setting works good and both lights turn on. I have not tried looking for an answer since I really wouldn't know where to begin so can someone lead me in the right direction. Thanx in advance
Jorge
Jorge
If the fans work but don't kick on when they should it could be a bad relay or fuse, have you checked them? If you don't have one already pick up a Haynes repair book for the 93-97's, only $15 and well worth the money.
dunno why people mess with the rad fans on these cars so much. Mine had them wired with 18ga into the ign fuse, after it melted the fuse panel and blew the fuse while on a 2 lane road with no shoulder i rewired them to the factory fan harness, both turned on and worked exactly like they should. Stupid F'n hillbillies.
Anyways yea what he said, i think you can even switch your relays just to check that they work, but that could be either a lincoln LS or a Lexus es300 that im thinking of lol. get my cars confused
