Question about Steering Controls.
Old 07-21-2011, 03:29 PM
M3xpress's Avatar
Default Question about Steering Controls.
Up until recently I didn't know the controls on the steering wheel were originally illuminated. If I ever want to fix this is, is it better for me to try to find two controls to swap out or try to take them apart and fix the bulbs?
I don't have any problems with the controls other than the fact they're not illuminated anymore. It's not that big of a deal, but it would be cool to have them lit up.
Old 07-21-2011, 06:07 PM
bigj2717's Avatar
The bulbs are soldered into the circuit board inside the control. You can take them out if you have a soldering iron but it might be easier to just find some with good bulbs
Old 07-22-2011, 07:29 AM
Ungrounded Moderator
WhiteBird00's Avatar
Check the fuse first. There are two 1-amp fuses labeled STG WHL CNTRL in the dash fuse panel. Fuse #3 is for the switch function and fuse #13 is for the switch illumination.
Old 07-22-2011, 11:09 AM
tsench's Avatar
this what i grab from ebay it come with difference color led
if u need link pm me
Old 07-22-2011, 03:00 PM
M3xpress's Avatar
I did not know there were separate fuses, I will check that.
