Unhappy with exhaust...ideas?
Just as the title says guys, 98 z, lt headers, offroad Y, magnaflow muffler.
As far as loudness goes, its great, but certain areas of the rpm range are raspy, almost like a straight piped hick truck lol! Not my style. Just would like a nice deep tone. Maybe A dynomax bullet muffler or just a regular flowmaster? Looking for others opinions, don't really care about the dual out, I'm just going to put a dump on it anyways. Thanks guys
You think the Y is to restrictive? Its a custom 3" stainless piece a buddy built for me, but i know the drivers side has somewhat tight bend before the merge. Don't really want to add a muffler, more like just change it out for something else lol. It sounds great except for certain areas... 2k under load... very retarded sound.
I have the same prob but mines from about 2k-3k. Lower it sounds great and higher its awesome just right there when I pull out from a light getting on it a little. I'm having a Magnaflow Merge put in either tom or next week. I'll try and report back.
I will get some tomorrow... was just hoping that wasn't it, lot of time invested getting him to make this one. The merge itself is great, but the drivers side before the merge does take damn near a 90 deg. bend.
Anyone done just a straight 40 series flow with a dump? I had a pair on my old 86 truck and they sounded great, just curious how one on this would sound. I thought maybe it had something to do with the stainless lt's and y
I have one as well...actually an ORY, small dynomax bullet and a 3" in/out flow 10...sounds incredible, only real rasp is around 4500 RPMs...but its hauling *** by then and just sounds mean.
That merge looks awful... if you can even call it a merge. That may be a source of some of the rasp. Also, are you still on the stock 2 3/4" exhaust piping after the Y-pipe? If so, that's not exactly a free-flowing exhaust. You're going from dual 3" pipes that merge to a single 2 3/4" pipe.
non catback started as a 3" flowmaster system, the muffler just **** out so it got a magnaflow. And i take back my previous statements. After reading on here I see a merge and a Y are deffinetly not the same lol yes mine don't look so hot after all. May have to have him fab a magnaflow merge in there...Just seeing if maybe a muffler would do the trick. Is there really any hp to be made changing the merge?
You sound just like me a couple years ago. I had the horrible rasp also and hated it. I threw away more money with different mufflers and combos and was never happy. I finally went with true duals all the way out the back with an x pipe and dynomax bullets. This was the sound I was looking for, no rasp and a mean nasty growl
http://www.youtube.com/watch?v=31Mk7LyQzac
Your merge is one of your problems, as stated that is not a very good merge at all. Check out my first attempt at a y-pipe posted below. You want a good merge collector and as straight of an angle going in as possible. Or goto a x-pipe and TD setup.
I plan on running a 4" flowmaster 1 chamber (delta force one they call it) out the back and a 4" cutout right before the axle.
https://ls1tech.com/forums/generatio...pt-y-pipe.html
