Rear end & suspension upgrade
so i bought a rear end (whole axle from wheel to wheel) from the south with 3.73 gears and NO RUST..so im going to put the whole thing in my car since i have 2.73 gears and a **** ton of rust while im there i wana update/upgrade some of my other stuff that should be done but im not sure what i should do for sure so im looking for some input...im not changing springs cuz mine are find and they are lowering springs and i already have a set of new shocks so im thinking things like LCA, sway bar, Panhard bar, maybe torque arm but those look spendy haha....and small things like brake lines, links and so on?
what would u do if u were in my shoes?
A UMI adj torque arm was the first thing I did to my suspension and it was worth every penny. But i think you have the right idea of what to do. Control arms make a big different too
Adjustable panhard rod for sure. LCA reloc brackets and rear LCAs wouldn't hurt, especially if you're getting wheel-hop. Rear sway bar change typically goes better with a front sway bar change to make sure they're matched properly; same with the brake lines - if you're going to do braided stainless, you might as well do all four corners.
Torque arm is never a bad idea, but one of the things I'd leave for last.
LS1Tech Premium Sponsor
I would do lower control arms, adjustable panhard rod, lower control arm relocation brackets, and adjustable torque arm. Theses are all parts you are going to have to remove to swap out the rear end and they are all parts that will really help the handling and performance of the vehicle especially since the car is lowered. If you are interested in any BMR parts shoot me a PM or give me a call here at the shop and I am sure I can work out some pricing for you.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Sounds good just give a call when you are ready and I will work up a custom package for you with some good pricing.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
