Misc Fbody and LSx parts
Category: Drivetrain
Price: $1
Part Fits: 93-02 Chevrolet Camaro, Corvette, 04-06 Pontiac GTO
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
1 New FTP 104mm lid
1 New TSP 100mm maf
(both still in the box)
1 ls7 intake
1 set of fast 50lb injectors
1 set of ls6 injectors
1 ls7 fuel rail
1 ls2 fuel rail
1 ls1 fuel rail
1 set of arp head studs for 2004 and newer blocks
1 set of eagle 6.125 h beam rods with arp 2000 bolts
1 New set of arp 2000 bolts for eagle h beam rods (still in packaging)
1 eagle forged 4 inch crank with 24x reluctor wheel
1 stock ls1 3.622 clean crankshaft
1 ls6 ported and shimmed oil pump
1 TSP custome cam 256/260 661/663 115+0 camshaft
1 FTP SSRA ram air kit
1 TNT 78mm power ring
1 TNT 90mm power ring
1 stock driveshaft with new 1350 u joint for rearend
1 stock driveshaft with new spicer 1350 yoke and new 1350 u joint, recently balanced
1 stock 10 bolt 4 channel rear end with 3.42 gears and 60k
1 set of kooks 1-7/8 off road headers for fbody
1 kooks 3inch y pipe with 3 inch cutout flanges welded in
2 f body oil pans clearanced for 4 inch crank
1 f body windage tray
1 f body pick up tube
1 k&n fipk kit for fbody
1 stock fbody radiator
1 stock fbody water pump
1 stock fbody crank pulley
1 set of center bolt valve covers
1 fbody t-56 bell housing
1 set of fbody from brake calipers
all the fbody spare tire equipment and covers
all fbody pcv plumbing
all fbody AIR pump plumbing and pump
1 stock fbody panhard bar
1 stock fbody torque arm
1 set of stock f body lower control arms
1 set of stock f body front upper and lower control arms
1 set of stock f body motor stands
1 set of stock cats never used
I have some prices in mind, but am willing to accept serious offers. PM me or call 9046262942 if you are interested in anything.
Thanks,
Blake
