Will 2001 SS rims fit my 1993 Z?
Old 07-27-2011, 07:15 PM
bbreeze93's Avatar
Default Will 2001 SS rims fit my 1993 Z?
i just picked up 2001 camaro ss wheels (17x9) for my 1993 z28. I couldn't find a thread on here with these rims. i could only find ones with ZR1 (17x9.5) but then again i am a noob to this site. I did find something one time about the 1993 hub being just a hair big, like .03 inches to be exact if im not mistaken. they suggested grinding the inside of the rim down with a dremel. Is any of this true? thanks in advance
Old 07-27-2011, 07:50 PM
bigj2717's Avatar
Yeah are a little smaller then the hub. http://shbox.com/1/4th_gen_tech2.html#wheel_mod Here is a write up of what you need to do
Old 07-29-2011, 03:52 AM
jarretthise's Avatar
Instead of grinding o your rim and affecting the structure, I would change out the hub and spindle set up. Aluminum rims needs all the structural secureness they can get. Just my .02
Old 07-31-2011, 01:41 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
trimming the inner hub section isn't going to hurt the integrity of the wheel
Old 07-31-2011, 02:54 PM
9WhiteCamaro9's Avatar
^ 2x on what he said.
Old 07-31-2011, 02:57 PM
oChristiano's Avatar
I didn't have to do anything to put my SS 10 spokes on my 96 z28..
Old 07-31-2011, 11:46 PM
Z28/2002's Avatar
FWIW
I had to trim my CETA wheels when I put them on my 94 Z28
Old 07-31-2011, 11:59 PM
94lt1white_bird's Avatar
The amount you have to grind off won't do **** in the long run go ahead and grind them down a hair that's all it takes I have done it multiple times
Quick Reply: Will 2001 SS rims fit my 1993 Z?
