Which Wideband for HPTuners?
Old 07-27-2011, 09:19 PM
BAMALS1's Avatar
Default Which Wideband for HPTuners?
About to begin tuning with HPT which wideband is best? Innovative LC-1? What all is needed?
Thanks
Old 07-28-2011, 12:08 AM
97lt1camaro's Avatar
Im using the lc1 kit from summit. Works like a champ, and super easy to install.
Im pretty happy with it
Old 07-28-2011, 06:52 AM
BAMALS1's Avatar
Ok thanks for the reply. That looks nice too btw
Old 07-28-2011, 06:59 AM
Phil'sC5vette's Avatar
I use the LM-1 for tuning. I recently purchased the LC-1, but returned it because the cord was to short for needs. I then purchased the LM-2.
I continue to use the LM-1 for all my tuning and use the LM-2 as back up. I plan to switch them soon and use the LM-2 for all my tuning and the LM-1 as back up.
There are several good one's out there just depends how much you want to spend and what is the application. I need to change my wideband from car to car. If I didnt do that, The LC-1 would work.
Old 07-28-2011, 08:02 AM
max1's Avatar
lc1....
Old 07-28-2011, 11:59 AM
BAMALS1's Avatar
I think I will have enough length with there being a bung on the outside of the collector on the driver side.
Thanks for the replies!
Old 07-28-2011, 02:48 PM
BAMALS1's Avatar
I just bought an LM-1 from a member here. Looking forward to learning.
Thanks again guys!
Old 07-28-2011, 10:49 PM
Tan327's Avatar
Never used an Innovative product but when I was searching for which wideband to buy a week ago I read so many threads full of people complaining about the LC-1 ..seems like you have to wire it perfectly(mainly the ground) and even then a lot of people could never get it to work right.
Not saying it's bad, just letting you know what I found doing a LOT of research. I found very few complaints about the AEM UEGO and decided to go with that, finished the install today so I can't say much about it ..the install would be a breeze for someone that is half decent at wiring, I am not so it took a while to get it working(completely my fault) but so far so good.
Old 07-28-2011, 11:16 PM
The major concern is that the ground location is the same as where the pcm grounds on the head. Pretty minor. I just butt connectors for all my connections with no issues.
Quick Reply: Which Wideband for HPTuners?
