truck intake or ls intake for a 5.3 and 75mm turbo
I have a 68 camaro that I am putting a 5.3 and 75mm turbo in with maybe 10-12psi for now. I was wondering if an ls intake would be better for performance than the stock truck intake. I know it looks better but not to worried about that. In the future i plan to do a little head work and a cam maybe forged internals and then crank the boost up. If the truck intake is just as good for performance I may run it and spend the money on other things i need.Thanks
Keep truck if ur redlined gonna b at 5500 to 6000 rpm truck intakes where built to make torque down low for smaller engines ls1 intakes for performance hp up high after 5500 to 6500 I'd say save cash buy proflow xt intake later
You can make power with both..... Me personally I would run whichever was cheapest or I could get a deal on......... Or if its for cosmetic issues.
Bozz
Bozz
thanks guys I was not sure on the power difference think maybe i will stick with the truck intake. I am also trying to figure out what size injectors,fuel lines,filter,and regulator to use? i am planning to run an A1000 pump inline. I have never done a FI car before so i am trying to learn everything i can from people thats aleady done it. Thanks for any recomendations
Looking to make 550-600 now and 700-800 after the forged internals. I want to run E85 but its not very common around here. I already have the trtuck intake it came with the motor so I may run it since its already paid for then I can upgrade later.
So what pump and injectors would you recomend? I would like to just buy the fuel system one time if I can. Thanks.
Only thing about the truck intakes is there ugly as sin. Kyle thanks for making me second guess my decision to put l92 top end on my truck.
Well I found a LS1 intake for $75 so I went and picked it up last nite. The biggest reason I did is I done some measuring and I don't think the truck intake would clear my hood so a $75 intake is cheaper than a big hood. Thanks for all you help.
