ls1 to ls6 PCV
Old 07-30-2011, 10:37 PM
LS-240's Avatar
Default ls1 to ls6 PCV
so i went from my 2000 ls1 pcv valley cover to an ls6. ls1howto says that i need 10" of 5/16" hose, and this entire time i was under the impression that that is all i needed to connect these two (whatever you wanna call'em) together.
after reading the site closely, i noticed that it says to use the PCV that was on the stock ls1. i've since thrown mine away, so i was wondering if i absolutely need to use the PCV on that hose, or can i just run a normal hose and connect the two points? i believe i've seen ppl run without it so i wanted to check.
Old 07-31-2011, 12:31 AM
sjsingle1's Avatar
do you have the old style or new style LS6 VC? old style uses a PCV in the hose........new does not
Old 07-31-2011, 12:34 AM
sjsingle1's Avatar
Old 07-31-2011, 01:20 AM
LS-240's Avatar
awesome, thanks man. it's the newer valley cover. that hose looks prebent. can i get that from autozone? it's 3/8" both ends, right?
Old 07-31-2011, 01:52 AM
R6cowboy's Avatar
I believe that pre-bent hose is a GM part only, a few dollars for it. I just did the same conversion. You do not need the PCV inline with that hose if you have the 2004+ style LS6 valley cover.
Old 07-31-2011, 02:25 AM
01ssreda4's Avatar
Call SDPC, they can hook you up with that hose.
Old 07-31-2011, 03:15 AM
The Scammer Hammer
dr_whigham's Avatar
The part # you'll need for the hose is 12594779
Old 07-31-2011, 01:09 PM
sjsingle1's Avatar
my local dealer had a ton of those hoses..........it was about 3$
Quick Reply: ls1 to ls6 PCV
