EPS 234/246 with boost?
I have an EPS 234/246 .602/.607 111LSA cam. I'm running an LQ9 stock bottom end w/ ARP bolts, and stock 317 heads w/ dual springs, LS6 intake manifold..CR of 10:1. I am going to be purchasing a Procharger D1SC in the next few days, and was wondering what everyones' opinions on the setup is? do you think this cam will work good with 9-10lbs boost? thanks
superchargers like more duration on the exhaust than the intake since the intake side is being force fed. If you look at the specs on it I could easily see this cam being addvertized as a supercharger cam. The LSA may be a little tight but that will make it sound a little meaner also. It will probably run like a raped ape once you get a few rpms in it.
It will be interesting to see what your FI version puts down.
The cam seems to do well in a 346ci LS1, see post# "134" https://ls1tech.com/forums/dynamomet...results-7.html
