Pacesetter LT's + Random Cat = HELP PLEASE
If one were to purchase a set of Pacesetter LT's with the Y-Pipe (Pacesetter PN 82-1161) then out of the 5 choices random technology gives you here (http://www.randomtechnology.com/pontiac.html) which one do I pick to make sure it all works together.
I am trying to avoid welding at all, if possible. For some reason I feel like those chances are diminishing by the day.
I emailed Pacesetter and got an email back that really didn't answer any of the questions I asked. But in their defense I did change my mind from using shorties to going with LT's.
Anyone do this setup before? Anyone think I should just use a stock cat?
So I am finding that this task is going to be a bit more complicated. Called up Random Technology, and they were so helpful. I am going to get some measurements and specs off the back-end of the y-pipe when I get it and Random Technology can put something together that will work for me. This will presumably bolt up to the latter half of the exhaust system.
Perhaps I won't have to weld after all.
