That didn't go well...
I made the mistake of snapping off the throttle body return port on the radiator, so I bought a new unit and put it in today. I fired up the motor after putting the new radiator in ad filling it full of coolant.... and low and behold the damn oil leak is STILL THERE. A couple of knowns: The intake manifold gasket is NOT leaking oil. Everything seems to be below that point. There doesn't appear to be any oil on top of the opti at all. (at least looking from the top) The stream of oil seems like it is coming from ABOVE the crank seal, likely from near the Opti seal. It flows down and around the crank seal "hump" in the timing cover, and down to the lip of the oil pan. It IS flowing down for sure, as I can actually see it pulse a little bit. The highest point I cna see it coming from is behind the drivers side of the optispark itself.
Is there another seal that could leak oil behind the opti besides the seal in the timing cover? Both O-rings on the opti shaft itself are intact and sealing, I can say that for sure. I'm pretty pissed consi9dering that I was almost 100% sure it was the WP seal when I tore it apart, as there were oil droplets sprayed on the underside of the WP and the bottom of the coil, indicating that oil was hitting something that spins, either opti or WP shaft. The opti was covered in a bunch of dirty looking old oil/grease, and took just a few minutes to wipe it all clean. This otpti was replaced about 2 months ago.
ANY ideas? I'm going to try to get a video of the leak itself tomorrow.
