carb my 95 LT1 advice???
Old 08-10-2011, 06:15 PM
GITSUM95Z's Avatar
Default carb my 95 LT1 advice???
i have been flirting with this idea. anyone have some part numbers on what intake to buy?
can anyone tell me what troubles im facing?
just curious. i appreciate any info on this. thanks
Old 08-10-2011, 06:36 PM
Big Al's Avatar
Sticking with the Optispark? Or going to a regular distributor?
Al 95 Z28
Old 08-10-2011, 07:52 PM
GITSUM95Z's Avatar
Im assuming changing to a regular distributor would be better. Like a msd pro billet.
I have enjoyed many years of usage out of my Dynaspark, with a msd opti style as backup. But if I change over why not eleminate everything. Am I thinking right?
Old 08-11-2011, 01:00 AM
Big Al's Avatar
If you put the distributor in the back you're going to have fun if you ever need to pull the intake. Have to remove the distributor first, not a lot of room back there, unless you cut the cowl.
Do a search here and you'll find threads about it.
Al 95 Z28
Old 08-11-2011, 01:28 AM
MasterTomos's Avatar
Why do you want to carb your lt1?
Old 08-11-2011, 02:04 AM
GITSUM95Z's Avatar
im just done taking the car to get tuned everytime i do an upgrade. i am going solid roller and the lt1 computer will not handle the rpm range so i was told ls1 change over or fast ecu. why spend all that money and continue tunning every time i turn around. the car is transforming into a bracket car to do some dely box racing. it is a whole lot cheaper and less time consuming to change carbs, jets ect. as for the dist clearence issues, i was thinking of do what some nhra stock & superstock guys do and run msd dist, with a shallow ford cap. this way clearence is not an issue. i am waiting response on the part numbers to make that work.
i found a ton of info on this swap on this site, "the full carb swap" it is incredible. the only 2 questions i have left before ordering what i need are.
1) can i still run the 6spd without computer?
2) i already run a msd coil. i already have msd 6al box. can i just use a msd pro billet dist and go directly to coil. similar to a points style but non point dist
hopefully these questions arent stupid
Old 08-11-2011, 02:07 AM
GITSUM95Z's Avatar
dont get me wrong i have enjoyed the fuel injection, however i just feel like i have just about reached my capacity with it on this build.
after 1 more year running a stick class its power glide time
Old 08-11-2011, 09:31 PM
z28racerlt1's Avatar
I went to a carb about 5-6 years ago. something like that. I would NEVER GO BACK.
I run a MSD crank trigger and crank trigger dist. It is low profile which helps when needing to remove it without dropping the motor. I did cut the cowl back to the firewall. You will probably have to do that anyways. Small blocks like spacers under the carb. The carb would hit the cowl if you run spacers. I currently am running a Super Vic with a 1" and a 1/4" spacer. I would like to run more but I don't want to cut the glass or get a lexan windshield.
I am not sure about your 6 speed question. But the coil should wire right into the 6AL box. I run a 7AL but they should wire just about the same.
Ken
Old 08-12-2011, 11:36 AM
GITSUM95Z's Avatar
thanks z28racerlt1.... i have already ordered almost everything i need to do this swap. i have seen many photos on this and i like what i see. i have already made so many changes to this car so some cutting isnt gonna be a big deal. i seen the crank trigger msd setup. is this hard to install, or is there any tips you have learned to make the install easier. i dont know much about the crank trigger stuff so any info would be helpful. im tossed up by the crank trigger setup, and the points style but instead of points installing pertronix ignitor solid state ignition system. i have been messing with the fi lt1 stuff for last 10 years that i am very rusty on my "old style" ignition stuff.... thanks agian for your input
Quick Reply: carb my 95 LT1 advice???
