Procharger j bracket install
I need to know which spacer do I use to mount the j bracket through the factory idler pulley. The install manual just says 1.875" or 1.75". Which do I use? The car is a '98 trans am with an A4 transmission.
Also the install manual says that a 2.65" standoff "could be" used in place of the 2.75" standoff on the lower alternator mounting hole if the bracket is being installed on an A4 car (to remount the transmission cooler lines mounting tab). Would I be correct in thinking "could be" means "needs to be" so the bracket lines up true.
Thanks guys,
Jason
Thanks guys,
Jason
here are some photos describing what i mean. i'msure there is some detail i am overlooking and the answer is probably staring me right in the face, i just can't seem to tell which spacer is the correct. the only thing i can come up with is that the spacer length must be determined by which year the vehicle is. i just don't know which year(s) go to which spacer!
thanks Jason
thanks Jason
thanks Jason
thanks Jason
From what I'm seeing the '98-'99 have a different spacer length than the '00-'02. The only problem is I don't know which spacer is for which model year. which spacer did you use on your car? Is your car a '99?
And the color install guide was compliments of the guy I bought the kit from. He sent it to me in PDF form.
Thanks Jason
Thanks Jason
LS1Tech Sponsor
Hi Jason, the absolute best way to figure it out is to put it together and see which combination keep the J Bracket parallel with the front of the block. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The following users liked this post:
fucter (12-30-2023)
Jason
