Lunati Dual valve springs?
Old 08-14-2011, 06:15 AM
ausls1's Avatar
Default Lunati Dual valve springs?
Lunati Dual valve spring kits good?
Found a Lunati dual valve spring kit rated to .660" lift that comes with, seals, etc, this is the write up for the kit:
With a maximum lift capability at 0.660-inch, the Lunati kit serves the majority of popular camshaft applications.
The kit is complete with dual valve springs, steel retainers, locks, valve seals and spring locators and represents a drop-in installation for many popular LS applications.
Lunati’s retainers and spring locators are CNC-manufactured from 4140 alloy steel. The locators pilot onto the valve guides and locate the inner diameter of the inner valve springs, preventing them from abrading the springpockets in the aluminum heads.
In common with all dual-spring retainers, these new Lunati types have a group of steps machined into their underside (which locate the upper registers of the valve springs) and a bore machined to accept the 7-degree valve locks.
The locks are equipped with inner bead locks and the 7-degree interference angle between the locks and the retainers is favored by many who believe it causes the locks to clamp the valve stems tighter. Through careful CAD and FEA design efforts, Lunati engineers have developed a new valve spring retainer design using wear-favorable alloy steel, yet nearly matching the weight advantage of Titanium.
For street/strip longevity, Lunati’s lightweight alloy steel retainer is unbeatable. Viton steel-jacketed valve seals complete the kit. The steel jackets ensure the valve stem seals remain tight around the valve guides and also protect the seals should the inner springs come in light contact with them. The Viton material is ideal for resisting heat and oil, particularly some of the more aggressive oil additives that cause ordinary seals to swell and distort.
Sound like a good kit?
Old 08-14-2011, 07:02 AM
DaFireMan's Avatar
good kit and price. ran those for about 15k miles on a ms3 without an issue. only reason they are gon offf that cause is because it has heads now
Old 08-14-2011, 07:29 AM
01ssreda4's Avatar
I'm running them with no issues.....
Old 08-14-2011, 07:31 AM
ausls1's Avatar
oh sweet, yeh i just sold my 218/224 114 lsa cam with 918 springs rated to .600" lift to get a bigger cam for my 383 stroker i'm going to put in instead and and came across this kit, cam i'm looking at has .617 and .624 lift, but if get a custom cam for FI might be a .580/90 lift but they'd still be good either way if i decide to step up in cam.
Old 08-14-2011, 09:57 PM
A.R. Shale Targa's Avatar
Love my Lunati Gold duals......595/.598
Old 08-15-2011, 02:16 PM
_max_POWER's Avatar
NOOB ALERT
Is there such a thing as too much valvespring?
Im considering these for my build and i was wondering if a beehive spring such as the pac 1518 or comp 918 would better suit my application.
setup:
stock 243's
futral f11 (228/230 .576/.595 114lsa
comp pushrods
ls7 lifters w/ ls2 trays
Thank you guys
Old 08-15-2011, 11:13 PM
run the duals and forget about changing them for 25000 miles
Old 12-08-2011, 10:18 AM
Hy82e's Avatar
Bump..... To keep some real world reviews coming in.
Just picked up a set of these Lunati duals. Should be going in a fresh set of 799's in the Nxt 2-3 wks. Hope there not overkill for the Eps 222/226 cam or similar I'm considering.
Old 12-08-2011, 10:21 AM
ThumpnZ28's Avatar
+1 for Lunati springs. I use em. No issues.
Old 12-08-2011, 10:54 AM
milkey57's Avatar
I use em as well no complaints here
Old 12-08-2011, 12:08 PM
Hy82e's Avatar
That's good to hear. What cam you runnin, and what other valvetrain mods are supporting it.
Old 12-08-2011, 01:43 PM
milkey57's Avatar
224/230 581/592 lift stock rockers with the trunion upgrade, and hardened pushrods.
Old 12-08-2011, 04:41 PM
The Scammer Hammer
dr_whigham's Avatar
I made up my mind and I'll be running them when I install my cam.
229/236 .631/.631
Old 01-23-2012, 06:47 PM
Ph.D. in HUBRIS
custm2500's Avatar
Glad to see all the good responces. I am ordering mine wed. night!!!!
Old 02-13-2012, 06:40 PM
Ph.D. in HUBRIS
custm2500's Avatar
Working on installing my springs tonight. The seals seem to be overly tight. Are they supposed to be extreamly tight. I am lightly taping them with a hammer(using an old one on top) and they aren't budging. Before blasing on them i wanted to see if I was doing something wrong or if they should go this hard. Don't want to mess them up!
Old 02-13-2012, 07:40 PM
milkey57's Avatar
I just put a deep socket on the seal and lightly tapped it with a rubber mallet. Also make sure the seal has a coating of lube on it.
Old 02-13-2012, 08:00 PM
MikeFSKSpeed's Avatar
What he said^ lube is good
I've sold a few sets of these. Lunati makes top notch stuff!
Old 02-13-2012, 08:02 PM
Matt0matic's Avatar
I have a set for a L92/LS2 combo coming together. I've heard they work well.
Old 02-13-2012, 08:07 PM
Gray86hatch's Avatar
Two sets on two engines. 5000 miles on one with no issues .600 lift
300 miles 7500 rpm and .660 lift no issues
Tim
Old 02-13-2012, 08:24 PM
Matt0matic's Avatar
Tim, what are your closed pressures set at with the street car? Have it shimmed up at all?
Quick Reply: Lunati Dual valve springs?
