Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
9 sec Trans am ws6 full interior car
Old 08-14-2011, 07:31 PM
dnkynrbk's Avatar
Default 9 sec Trans am ws6 full interior car
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $22000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
$22,000 NO LOW BALLING IF NOT INTRESTED PLEASE DONT PM ME THANKS
I HAVE OVER 40K INVESTED IN THIS CAR IM JUST TRYING TO MOVE IT TO GET SOMETHING ELSE.
1998 WS6 TRANS AM has 99,000 miles on the body and 1,800 miles on the new motor
car runs mid 9.60@143 on 200 spray on motor runs 10.66 with a nitrous cam and nitrous stall with more timing na you could run a low10.s
This is with a safe tune and 15 degrees of timing. car will run 9.30s easy
ENGINE 408 STROKER $10,000 invested
12-6 comp. By EAGLE Machine shop Diamond N20 pistons -2cc pistons ALL ASSEBLY HAS BEEN HEAT COATED, rings are gap for a 350 SHOT Callies dragon slayer crank .Callies rods,ARP bolts
custom grind Cam motion cam 646 lift nitrous grind for the set up. will give out specs for series buyers
Yella terra rollar rockers lites, cadilac ctsv race lifters
Trick flow push rods
Ported Melling oil pump, Rollmaster double rollar chain. ARP bolts, ARP main studs,arp head studs
Nitro Dave direct port. 200 shot up to 400 shot comes with all jets
Ported Fast 90 intake NW.TB. $1200.00
42 lb injectors green tops
ASP underdrive pully
Truck coils MSD wires 8.5 wires
WS6 store oil catch can.
When I put this motor in I put in a new alternator,starter and water pump all less then 6 months old and have a lifetime warranty from ORIELLYS AUTO PARTs STORE.
FIPK K&N FILTER
EXHAUST:
Kooks stepped Race headers stainless steel 1 3/4 1 7/8 to ventura 3 1/2 collecter 3 1/2 exhaust with bullet mufflers.$1200.00 new NOT including the 3 1/2 Dynomax bullet mufflers and exhaust
Patriot stage 3 heads. Heads have been reworked and fully ported RACE HEADS by Eagle machine shop 3 angle valve job. and milled
Flow specs given out when purchased I have over $2,000. invested in these heads.
NITROUS. NITROUS dave D.P. all hardlines, NITRO dave dedicated fuel cell , NOS mini controler. car runs 1 15 and one 10 lb bottle with billet alum bottle Bracket. all upgraded parts for the nitrous. I have over $4,500 invested in the nitrous kit alone. Has all 6an lines
Tranny: was freshend on 6/30/2011 has 150 break in miles.
PerformaBuilt T400 built for over 1200hp.w/ brake Tranny was over $2200.00
NEAL CHANCE N20 racing converter 4200 na 5200 SPRAY. stall is $1450.00
TCI flex plate.
B&M rachet shifter new
Custom nitrous steel drive shaft. 1350 yoke and u joints.
6pt cage by 417 RACING custom built for the car.
REAR END:
MOSER 12 bolt full spool MOSER 3:73 gears
Wolf roll over bar welded
UMI TA chasis mount torque arm
BMR pan. bar, adj. control arms, sub frame connectors
Yank T400 tranny brace
QA R series shocks all the way around the car. 12 way adj 315lb QA1 SPRINGS
WHEELS.
I have BOGARTS and have fairly new slicks. Front are ET fronts brand new bought 2 weeks ago. back are ET drags M/T
Brakes: slotted rotors with Hawk brake pads
FRONT bumper delete from burkhart chasis
Has a AEM wideband, dynotune digital nitrous pressure gauge. tripple pillar pod.
Car has all the air bags and has never been torn apart
I also have all the air cond. equip. to put back on it if you want a fast street car this is it. I post up interior pics later. will come with the factory leather grey seats.and factory carpet
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid294.photobucket.co m%2Falbums%2Fmm112%2FJSFORGED408%2F100_2396.mp4">
Old 08-17-2011, 12:34 AM
Fbodyjunkie06's Avatar
What are you looking for? F-body? Turbo? Trades?
Old 08-18-2011, 10:13 AM
dnkynrbk's Avatar
I bought a FRC I may build. I may take another F body on Trade
Old 08-20-2011, 12:28 AM
dnkynrbk's Avatar
bump for the weekend
Old 08-20-2011, 11:25 AM
dunrdr's Avatar
Sell as a roller?
Old 08-21-2011, 09:21 AM
dnkynrbk's Avatar
Would for around 9500
Old 08-21-2011, 05:27 PM
dunrdr's Avatar
Pm me a few more details on how youd sell it as a roller
Old 08-28-2011, 03:58 PM
dnkynrbk's Avatar
Old 08-28-2011, 10:29 PM
Brad Hutchcraft's Avatar
This car is BAD ***... So many bench racers could walk by this car on the street and think its a 450 HP car with some Nitrous, and keep walking.. With out a clue that this bad boy puts out 4 digit power to the ground... And the best part of it all, is how reliable it is! Drive to the track, switch tires, win the weekend grudge races, switch tires, drive home... No bullshit. I love that car, and John is a very smart, dedicated racer. For $22,000, you could be campaigning a dialed, proven 9 second car... That's ****** bargain..
Good Luck, Man... Someone is about to get ALOT of car at the right price...
Bump it up!
Old 08-29-2011, 07:42 PM
indianakid's Avatar
message sent
Old 08-30-2011, 07:09 PM
dnkynrbk's Avatar
bump for the week
Old 08-31-2011, 06:43 PM
dnkynrbk's Avatar
bump for the week
Old 08-31-2011, 08:04 PM
1972_Z-28's Avatar
Interested in 05 V?
Old 09-03-2011, 06:54 PM
dnkynrbk's Avatar
Bump for the weekend.
Old 09-03-2011, 11:48 PM
spinny's Avatar
Amazing car! Not trying to low ball you by ANY means but if you're in a jam and need to get rid of the car fast I have 15K.
Again - please do not be insulted!! your car is WELL worth the asking price but I only have 15K to spend.
GLWS!!
Old 09-05-2011, 05:33 PM
dnkynrbk's Avatar
Im not in a pinched to sell it lol, Just bored with it and building a NA camaro as we speak. Thanks for the offer though
Old 09-05-2011, 06:41 PM
LSXFORMULA99's Avatar
thats my friends corvair wagan u can see in the pic at the track. lol nice car man
Old 09-06-2011, 10:24 PM
dnkynrbk's Avatar
lol thanks. Just put a Brand new set of Et slicks on it and hoosier fronts this week. I may let them go with the car just depends on the selling price. Also I can pull the nitrous off it and lower the price some.
Old 09-07-2011, 08:18 PM
dnkynrbk's Avatar
bump for the day.
Old 09-07-2011, 11:20 PM
spinny's Avatar
Right on man! Just figured I'd give it a shot, thanks for not taking offense to my offer - I know it's way low but it's all I have to work with.
Bump to the top!
Quick Reply: 9 sec Trans am ws6 full interior car
