One of a kind blown WS6 convertible w/ cage 470RWHP
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $17000
Mileage: 65000
Private or Dealer Listing: Private Listing
Location (State): MN
Color: Black
Transmission: Manual
* Near perfect paint and interior 9/10 no rock chips!
* All custom parts have been professionally installed and are easily removed if you want to bring the car back to stock.
* The turbo spool and blowoff valve sound is amazing. Extremely fast Gobs power and torque at all Rpms.
* Have 15k in custom aftermarket parts.
* Built stage 2+ T-56 by The Gear Box with Timken bearings good to 700hp+
* Autometer guages: Digital Air/Fuel ratio, Boost psi, & Fuel Pressure
* Intercooled Garrett 67mm BB Turbo with oil pump failure alarm
* Methanol Injection system with knock sensor warning alarm
* 60 lb. injectors w/ 255 LPH Walbro fuel pump
* Electronic boost controller w/ in dash switches (Set for 5psi low and 8psi high)
* Monster stage 3 clutch good to 750hp!
* Tick adjustable master cylinder
* 6pt Wolfe bolt in roll cage w/ swing outs (easily removable)
* HP Tuners Pro
* SLP Line Lock
* Extra set of 6.0 LS2 317 casting heads. This will lower compression by a point so you could run 12-14 lbs of boost and make some serious #'s
* New Black C6 motor sport rims
Email for addition info or photos. Or call 952-239-0971
