Presoaking lifters?
Old 08-18-2011, 05:48 PM
fat tony157's Avatar
Default Presoaking lifters?
I am about to install my new ls7 lifters in my 4.8, but I want to make sure I do it right. Would you guys recommend presoaking the lifters in oil overnight before installing them?
Old 08-18-2011, 05:50 PM
Darkman's Avatar
Having them full of oil certainly won't hurt, but you probably do not need overnight to get that done.
Old 08-18-2011, 05:56 PM
Well, my new cam doesn't come in until monday. I think I'm just gonna leave them completely submerged in oil until then. Thanks
Old 08-18-2011, 08:57 PM
crainholio's Avatar
Mine ended up soaking for over 2 days, took longer than expected to get the deck surfaces and bolt holes/threads cleaned and prepped.
Old 08-18-2011, 09:33 PM
1badWS6's Avatar
I let mine soak overnight in oil but I'm sure that's overkill.
Old 08-19-2011, 09:56 AM
usmcz28's Avatar
I usually only soaked them for 30-45 minutes and then put them in, haven't had an issue so far.
Old 08-21-2011, 04:37 PM
TransAmcoupe98's Avatar
more than an hour is overkill, not like they are plants drinking water.
Old 08-21-2011, 06:07 PM
2000_SS's Avatar
no such thing as overkill. if you have the time to let them soak for a month, do it. i would give them at least an hour or so though. you'll be able to see small air bubbles coming out of them for some time. i usually let them sit over night.
Old 08-21-2011, 07:25 PM
Havoc40's Avatar
Presoaking makes sure the lifter is pumped up. There is no over-kill. Quickest way is to place the lifter in whatever fixture you can come up with to hold the part verticle, put that in a 2litre (or whatever fits with your fixture) cut in half, fill with oil, place under a drill press, chuck a pushrod up in the drill press, center the part up with the pushrod, and manually pump the lifter up til you see no air bubbles.
Old 08-22-2011, 02:25 AM
RobZ's Avatar
Would a lighter weight help better like 5w vs 10w?Need to know I have to replace my lifters soon.
Old 08-22-2011, 09:05 AM
miker2's Avatar
all you have to do is submerge them and then use a pushrod to pump them a few strokes.no soaking time required.
