11 Second Club - 11.76 Seconds in the 1/4 mile on new build
speedtigger
08-19-2011, 09:20 PM
The first trip to the track on my new build yielded a 7.46 @ 92. ***UPDATED*** 11.76@113.5 at Bradenton Motorsports Park. It seem to be pretty perfectly tuned right out of the box. Small changes in jetting and timing did not seem to affect the ET or MPH much at all. So, it must be close.
Here are some times slips form the 1/8 and 1/4 and video from the 1/8:
http://www.youtube.com/watch?v=-Jc2_WygX6A
EZZZE
08-20-2011, 04:12 AM
That is a sweet ride! Congrats on the bottom 7's in the eighth. That should easily be an 11.70 or so. I went 7.33 and it was an 11.51 in the quarter.
hookngo
08-20-2011, 04:34 AM
Looks real good
speedtigger
08-20-2011, 06:31 AM
I just read in the stickies that I am supposed to say "what it took to get it done". So, here is my combo:
1965 Skylark hard top 3500 pound even with spare tire and full tank of gas
LQ9 used - 55k miles from junk yard
TSP LS6 Stage 1 CNC ported heads
Comp Cams XR275H12 camshaft 222/224 .566/.568 on 112 with 110 ICL
Performer RPM Intake manifold port matched to heads
Pro Systems custom carburetor 780 CFM
Doug's 1 3/4 long tube headers with 3" collector
3" full dual exhaust with X-pipe and Walker Super Turbo mufflers
TH200-4R transmission
Circle D 2b 245MM 3000 RPM stall converter
3.90 rear gears and eaton posi
All stock suspension with urethane bushing, boxed control arms and monroe-matic shocks
Mickey Thompson 275/60R15s @ 15 PSI
speedtigger
08-21-2011, 03:43 PM
I went to Bradenton Motorsports Park today. Brutally hot. I got two runs in before the track went away. When I left the bracket racer next to me measure the track temperature at 135 degrees! Everyone was spinning. But here are the two clean passes I got off first:
blk/slvr02ss
08-22-2011, 07:03 AM
Great times for the Florida heat ! What does the car weigh ?
GWagner
08-22-2011, 07:13 AM
Great times, but man are you dangerous off the line. Nice R/T's.
speedtigger
08-22-2011, 07:32 AM
3500 with a full tank of gas and the spare in the trunk.
I was at sunshine drag strip. I was not so focused at Bradenton yesterday.
Mystery Bird
08-24-2011, 12:44 PM
Nice going, should get better with colder air coming soon. I can't believe your car weighs less than mine.
blk/slvr02ss
08-24-2011, 05:09 PM
3700LBS Thats heavy for a 4th Gen ! My 02 Camaro SS A4 w/ Just no front sway bar and no front pass seat w/ Weld Pro Stars weighed 3265 lbs w/ out me in it.
blk/slvr02ss
08-24-2011, 05:12 PM
You need to bring your Skylark over to PBIR some time so i can see it or next time i am over in Largo to visit my Parents maybe we can go to Tampa Dragway/Sunshine Speedway or The Wing house !
speedtigger
08-24-2011, 07:14 PM
Is that the track they used to call Moroso?
blk/slvr02ss
08-25-2011, 05:19 AM
Yup thats the one and all new as of 2009 and hooks up great w/ a all concrete 1320.
speedtigger
08-25-2011, 05:57 AM
I always liked that track. I have had some great times there. I have only raced there once, but I have spectated many times at major event including the original World's Fastest Street Car Shootout series back in the day.
Mystery Bird
08-25-2011, 07:41 AM
My 3700lbs would be with me in it and 1/4 tank of gas, that is what I consider race weight. I weigh 190 so that would bring it down to about 3500. TA's are generally heavier than Camaro's too.
