4l80e shifter
I too have found that the B&M Pro Ratchet shifter is a good choice. I have installed many of these shifters for guys over the years and have found them to be very durable and reliable. Not to mention I've never had a complaint from a client about one either!
g
g
g
g
on the B & M, you rem a pin that allows for 4th gear-part of the problems with alighnment is where the cable mounts to the shifter housing, the mtg tab on the cable can go either outside or inside the housing, i forget which way, but if not correct, the shifter will not match the ratio on the trans lever
i have told B & M they need to make it clear how it goes, other than the picture
